How many trailing arm shims is "normal?"
Once the car goes in for it's safety (tomorrow) I'm going to resume doing the home 4 wheel alignment.
What I was wondering is: how many shims does everyone else have in the back of their car? I know they are mass produced, thus the shims, just wondering what's normal - I know they should be snug, but how snug is snug? When do I stop adding the thin shims? It's not like I can stick my feeler gauge in there and measure clearance.
I think it was/is a bit toed out (just a visual, I ran out of time adjusting the camber.)
My car had (factory I think based on the rust)
Driver's outer: 1 big
Driver's inner: 1 big, 2 medium
Passenger inner: 1 big, 1 medium, 1 thin
Passenger outer: 1 big, 1 medium, 1 thin
adding/removing shims - does anyone know how much a shim change works out to at the wheel? If I moved one medium (1/8" ?) from the inside to the outside, that'll add toe-in, but is that 1/8" at the wheel? 1/4? 1/16? Trying to know before I move them, they're just a bit of a pain to put in.
I see also that changing one setting affects the others... it's not hard to do a driveway alignment, it's just a lot of time. Jack it up, adjust, lower, back up, drive forward, slip slurpee, rinse, repeat.
I would keep putting shims in until you can't get anymore in without prying the frame apart, then when you tighten up the pivot bolt it will pull the frame together enough to tighten them up good.
I'm not sure how much each shim changes things at the wheel, it may be trial-and-error to figure that out.
if you don't want to keep jacking up the car to adjust the alignment, try using a set of (4) four wheel car dollies from harbor freight, I found they raise the car just enough to get to most things (it is tight though), that way the weight it still on the suspension and the wheels can move and "settle in".
I did "paint" the shims with anti-seize to make removal less torturous.
OPINION:
AS for doing a driveway alignment in regards to the shims for setting the toe. I would not do this only because I have seen what changes occur on the computer screen to the alignment specs even when a thin shim is changed from one side to the other. To each his or her own....unless you have the "old school" measuring devices to get it set correctly. I prefer using a laser alignment machine. But that is just me.
DUB
OPINION:
DUB
Then I start doing the math in my head of how many man-hours are involved and I start thinking: I can do it and save me a lot of money.
Combination of stubborn and stupid I guess.
I just wanted to make sure I wasn't forcing too many shims in, or not enough. First Vette. (Had many cars, first Vette.)
I had a dirt track Camaro, and my buddy has a Formula V, so I know how to measure everything, it just takes a long time, especially because yes, I suspect moving a shim from one side to the other changes the toe-in, and probably also the camber a bit too. Plus changing the rear ride height affects the front, etc. It's like timing and idle - you go back and forth.
I guess I just go: every dollar I don't have to give to a mechanic is one more dollar to spend on the car. Yeah, that's it.
My name is Ray and I have a car problem.
The final shim was intended to be helped into place with a hammer meaning that there was very little compression of the trailing arm pocket walls when the bolt was torqued.
If an owner finds that they have lots of shims left over from a new set, it usually means that someone before them didn't install enough shims and the pocket is partially crushed.
