Once again thanks for the help!
I'm installing the upper ball joints on the 69 and have a question
The ball joint is installed from the top
But the rubber around the joint will not allow the base of the joint to sit flush. I'm guessing I need to pull the rubber boot down and shimmy the ball joint through the hole and pull the rubber boot back on?
Or is something wrong here? I got the suspension kit from ecklers.
Reason: Finally able to upload a pic!!
