Rear end question
Old May 15, 2013 | 03:16 PM
Sully1882's Avatar
Sully1882
Default Rear end question
Took the ole 72 for a spin around the block to get gas and man was that fun! It's so nice to actually get to drive it a bit after all I've done to it over the last 5 years. I'm supposed to have a 3:55 rear end gearing. At least that's what the codes show on the underside of the pumpkin. But it sure does seem that it is geared lower than that. What the general guestimate equation where something like get going in third gear and get it to a certain MPH and then see what the RPMs are? I've read it here somewhere an can't remember now. Anyone have a clue what I'm talking about?
Sully
Yes I know I haven't got pics up yet but I still have to finish the alignment of front bumper, a bit more work on fitting of interior panels, and other odds and ends then ill get some pics up.
By the way it's a 72 coupe with stock 350 and 4 spd
Old May 15, 2013 | 03:19 PM
classic72's Avatar
classic72
I have a '72 LT1 and at 65 MPH my RPM's are around 3500....I have a 4 spd with 4.11's
Old May 15, 2013 | 03:40 PM
Rally68's Avatar
Rally68
there are gear ratio calculators on this forum and elsewhere on the web. if it were me, i'd jack up the rear end (both wheels off the ground), car in neutral, make a chalk mark on the bottom of your tire and on your driveshaft. spin the tire one full revolution and count the number of driveshaft revolutions. 3 1/2 revolutions = 3.55
Old May 15, 2013 | 03:49 PM
Sully1882's Avatar
Sully1882
Looks like I'll be getting out the kids sidewalk chalk. I do hope it's a 3:55 and not lower Bc I am wanting to drive this to work and back during nice weather which is a 30 min highway drive.
Old May 16, 2013 | 12:11 AM
Skip Burney's Avatar
Skip Burney
I agree that's the easiest way to do it without counting gear teeth.
Old May 16, 2013 | 07:40 AM
lavery48's Avatar
lavery48
I get confused on this, is 4:11 lower than 3:55 ? Higher the number , lower the rato ?
Old May 16, 2013 | 10:31 AM
my 76 ray's Avatar
my 76 ray
Yes. With a 4.11 the engine turns 4.11 times to turn the wheel one revolution. With a 3.55 then engine turns 3.55 times to turn the wheel one revolution.
The 4.11 will allow the car to accelerate faster off the line at the expense of gas mileage and higher revs at any given speed.
Old May 16, 2013 | 11:06 AM
jackwabbit703's Avatar
jackwabbit703
Sully
take it out to highway and observe speed and RPM. If you have 3.55 gears, you'll be doing about 55 - 56 MPH at 2500 RPM.
If you have 3.36 gears, about 60 MPH at 2500 RPM. If you have 4.11 gears, YOU WILL KNOW without even looking at the speedo.
Old May 16, 2013 | 11:36 AM
Sully1882's Avatar
Sully1882
thanks wabbit! That's the info I was looking for, just a kind of guesstimate! Are those numbers with the trans in 3rd?
Sully
Old May 16, 2013 | 12:30 PM
Rally68's Avatar
Rally68
Just to clarify, this is more accurate if you substitute "driveshaft" for "engine." Engine speed only matches driveshaft speed in 3rd gear (1:1) on a THM400/350 or 4th gear on a Muncie. The numerical ratio is the number of teeth on the ring gear divided by the number of teeth on the pinion gear.
My 3.73s have 41 ring/11 pinion = 3.727
Old May 16, 2013 | 01:09 PM
Sully1882's Avatar
Sully1882
so with a 4spd muncie I should get up in 4th gear and at 2500 rpm I should be around 55-56 MPH? Is that correct? That is IF my rear gearing is a 3:55...
Old May 16, 2013 | 01:17 PM
jackwabbit703
If you have 27 inch tires.. YES or very very close. If you have 26 inch tires.. subtract about 2MPH. I could be wrong but you might have 3.36 gears instead 3.55. Which is not a huge difference in performance but you will have higher MPH at 2500. about 60MPH instead 56MPH.
Old May 16, 2013 | 01:24 PM
Sully1882's Avatar
Sully1882
Im not sure about the wheel sizes... they are stock 2002 corvette thinspokes 17" in the front and 18" in back with the back tires being 275/40-18.
Old May 16, 2013 | 01:33 PM
jackwabbit703
That size tire is almost 27 inches. 26.6 inches to be exact.
To Rear end question
