Rear Compartment Light!
Old May 22, 2013 | 12:17 PM
Brcmpbl's Avatar
Brcmpbl
Default Rear Compartment Light!
How, on earth, do I get at the bulb in the rear compartment (glove box) to replace it? Looking at the AIM, it appears the little cover thing with the lense in it just pops over the light and switch and is maybe stapled in there? Anyway, I don't like pulling on stuff unless I know it is ok...it's 43 years old!
Old May 22, 2013 | 01:06 PM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
As I recall, I think you can access it from the jack compartment if you remove the tray in that compartment.
Old May 22, 2013 | 01:10 PM
Mooser's Avatar
Mooser
IIRC you just pull the whole thing up. The bulb is basically on the back of the plunger switch
Mooser
Old May 22, 2013 | 01:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mooser
...you just pull the whole thing up...
Bingo.
Old May 22, 2013 | 03:37 PM
Brcmpbl's Avatar
Brcmpbl
Once every 10,000 jobs, there's an easy answer. Thanks.
Old May 27, 2013 | 12:04 AM
Brcmpbl's Avatar
Brcmpbl
Mooser
I spoke too soon and remain a little confused...do you mean pull the whole compartment door assembly out or pull the plunger assembly out? I gave the plunger assembly a little tug (without removing anything) and it doesn't want to move at all.
Old May 27, 2013 | 06:28 AM
Blue73Shark's Avatar
Blue73Shark
Mooser is correct. Pull the "plunger" out to get to the bulb. Do it gently but firmly. It may be binding on something. Since the compartment is too small to get your head in to get a look, use a small mirror.
Fran
Old May 27, 2013 | 07:43 PM
gr8t73's Avatar
gr8t73
It should be snug but not so tight it won't come out. Try going through the jack storage compartment & pushing up on it while pulling from the top side, works for me. Good luck.
To Rear Compartment Light!
