-69 cylinder head casting numbers
Old May 26, 2013 | 09:40 AM
1969Turbo-Fire's Avatar
1969Turbo-Fire
Default -69 cylinder head casting numbers
Hello i remove valve cover and...
found casting numbers.. what these numbers mean....
3917291
B208
GM 24
Old May 26, 2013 | 10:24 AM
Alan 71's Avatar
Alan 71
Hi 69T-F,
I believe the casting # 3917291 was used for 300 and 350 hp engines during the 68 model year.
I believe the B208 casting date indicates a head cast on February (B), 20th (20), of 1968 (8).
I believe The GM24 is a mold designation.
Regards,
Alan
Old May 26, 2013 | 10:25 AM
Mike Ward's Avatar
Mike Ward
Wrong casting number and date for a '69.
Old May 26, 2013 | 12:01 PM
1969Turbo-Fire
1969 convertible..Car was sold to me as 350HP but i discovered that it is matching numbers 300HP car (HZ in engine block)
But it has 350HP valve covers 350HP sticker + 350HP center console decal. Sticker tuning?
what is difference 300HP and 350HP engine? Cylinder heads?
Old May 26, 2013 | 05:47 PM
Phil Zell's Avatar
Phil Zell
ditto,
Old May 28, 2013 | 05:27 PM
1969Turbo-Fire
ok ok ... i belive... but what these numbers mean...
Old May 29, 2013 | 10:05 AM
LS4 PILOT's Avatar
LS4 PILOT
L-46 was HP block with 4 bolt mains, special performance cam, big valve heads, Higher compression, forged crank , forged rods, special pistons, deep groove pulleys , air cleaner is diff, pretty much everything is different . Nearly every major component part number is different. L46 is a very cool engine option for the day .
Old May 29, 2013 | 03:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...1969 convertible..Car was sold to me as 350HP but i discovered that it is matching numbers 300HP car (HZ in engine block)..
Not with the 291 heads you asked about.
...But it has 350HP valve covers 350HP sticker + 350HP center console decal. Sticker tuning?...
You can stick a sticker on anything.
What are the numbers stamped on the pad?
To -69 cylinder head casting numbers
