T-Top pads and brackets
Old May 28, 2013 | 12:56 PM
Mariana's Avatar
Mariana
Default T-Top pads and brackets
need some help. I got some pads from a guy for cheap but the metal brackets are missing. Look at the pics and give advice.
http://imageshack.us/a/img10/787/ttopbracket.jpg
There are 2 pics, one showing and one link. I been tinkering with imageshack pics.
Old May 28, 2013 | 01:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I can't really tell what you've got based on your pics. Are these Corvette trim panels? Correct model year for your car?
Old May 28, 2013 | 01:22 PM
Mariana's Avatar
Mariana
they are correct. 1973. Im sure you know this but the brackets and velcro encompass the pad on the right aw various places. they line up the actual top but I have bee unable to find the brackets. Would better pics help?
Old May 28, 2013 | 01:23 PM
Mariana's Avatar
Mariana
http://imageshack.us/a/img18/1386/ttoppads.jpg
Old May 28, 2013 | 03:31 PM
Alan 71's Avatar
Alan 71
Hi M,
I THINK those are 78-82 fiberglass roof panels.
They appear to be very different than the earlier year's panels.
I think you need to be looking for the later parts. Will the locating and locking mechanism used on these later panels work on your 73?
Regards,
Alan
Old May 28, 2013 | 04:50 PM
gbarmore's Avatar
gbarmore
If you're missing some of the metal brackets that the Velcro buttons are riveted to you may be out of luck, I could not find a source when I was looking for them. You can get the Velcro buttons, but not the metal brackets. If you do find the brackets you might want to try Goop brand household adhesive to re-bond them to the headliner, it works very well because it soaks into the fiber board a bit and remains slightly flexible, unlike a typical epoxy. Your donor headliner panel looks a bit rough, it might work just fine for your project, but all things considered it might just be better off buying new roof trim panels (Yeah, they are expensive!).
Old May 28, 2013 | 06:20 PM
Mariana's Avatar
Mariana
Originally Posted by Alan 71
Hi M,
Regards,
Alan
The picture has the fiberglass top on the left and the pad on the right.
Old May 28, 2013 | 06:32 PM
Mariana's Avatar
Mariana
The "new" ones i looked at are the newer versions that are screw on not velcro.
Old May 29, 2013 | 08:26 AM
Alan 71's Avatar
Alan 71
Hi M,
My only point is those are 78+ up tops, not 68-77 tops, and I don't know if the mounting/locking hardware that fits those tops will fit your 73.
Regards,
Alan
To T-Top pads and brackets
