lost pushrod piece
Old Jun 1, 2013 | 06:08 PM
endoman's Avatar
endoman
Default lost pushrod piece
A 1" piece of pushrod fell between the lifter bore and cam. I heard it drop into what i think is the oil pan. Can this cause a problem? The engine is a 1972 454.
Thanks,
Rob
Old Jun 1, 2013 | 06:16 PM
rene040269's Avatar
rene040269
You dropped a rather large hardened piece of steel into your engine between all kinds of moving engine parts, you cannot locate it anymore and your question is if this could cause a problem....
Seriously?
Old Jun 1, 2013 | 06:22 PM
qwank's Avatar
qwank
if you're sure it's in the oil pan. pull out the drain plug and stick a pencil magnet in the drain hole and go fishing
Old Jun 1, 2013 | 07:03 PM
Bagmup's Avatar
Bagmup
Yep, pull the sump plug and get a magnet in there.
Old Jun 1, 2013 | 08:31 PM
TimAT's Avatar
TimAT
Seriously?
Alternative plan is to just start it. If it's someplace it shouldn't be, it will reappear.
As I see it, the options are go fishing as mentioned or drop the pan.
Old Jun 2, 2013 | 06:17 AM
oldschoolvette's Avatar
oldschoolvette
its got to come out before you start the engine up
Old Jun 2, 2013 | 08:26 AM
oldalaskaman's Avatar
oldalaskaman
I would drop the pan, there are other things you can upgrade while its off
Old Jun 2, 2013 | 09:37 AM
dmaxx3500's Avatar
dmaxx3500
if you ''broke'' an end/piece of a pushrod,you'd better be checking any and all other valvetrain parts,lifters,rocker arms,cam,pushrods,springs,,do you at least have the intake manifold off?,,you have bigger problems then a broken pushrod in the valley
To lost pushrod piece
