Separating Panels
Old Jun 4, 2013 | 06:48 PM
longtime's Avatar
longtime
Default Separating Panels
Hi,
This is my first post. I have gotten help from many past post. Thank You for the knowledge.
The hood that came with my 69 has a large whole where a hi-rise double carb setup is. I want to change it back to a single.
I purchased a hood off of craigslist with one of the hinge mounts missing, ripped right out. I can see that the hood it is two pieces can they be separated to repair it?
Any help is much appreciated.
Old Jun 5, 2013 | 05:15 AM
terrys6t8roadster's Avatar
terrys6t8roadster
seems like you're trying to use the top of one hood and the bottom of the other. a high guality heat gun and a wide blade [3 inch] thin chisel [1/8 inch], just work your way around. should separate fairly easy. most bonding joints on our chrome c3's come apart that way.
Old Jun 5, 2013 | 08:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by terrys6t8roadster
...should separate fairly easy...
Separate, yes. Fairly easily, maybe not so much. Work slowly.
Old Jun 5, 2013 | 10:10 AM
longtime's Avatar
longtime
Thank you terrys6t8roadster and Easy Mike. I will give that a try later today. I still have the high rise double carb setup. Who knows maybe some day when gas is .25 cents a gallon again I may use it. I guess I can always dream because I am certainly not moving to Saudi Arabia lol.
Is there any chance that anyone out there has a right side hinge mount??? Or should I be asking this question in the Parts/Wanted for sale?
Regards,
John
Old Jun 5, 2013 | 12:07 PM
lvmyvt76's Avatar
lvmyvt76
try posting it there also, it doesn't cost any more to do so.
Old Jun 5, 2013 | 02:51 PM
longtime's Avatar
longtime
Thanks lvmyvt76. Your right didn't hurt at all. I am a little slow at this computer stuff but I am catching on.
To Separating Panels
