Driver window problem
Old Jun 4, 2013 | 10:27 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default Driver window problem
Hi all, the last 2 times I have got the 78 out for a drive the drivers window has gave me problems. It rolls up slower and seems to bind up near the top. Also when near the top it is about 1 " inside the weather strip, so I have to roll the window up with the door open then close it so the window will stop in the correct spot in the wether strip. I have never had the door apart, I know at there is a regulator in there that the window tracks on to raise and lower and there is a motor. Does anyone have any suggestions as to what might be going on? Is something loose, broke? Any ideas or suggestions are welcomed... Thanks.... Keith
Old Jun 5, 2013 | 06:30 AM
scottw's Avatar
scottw
May have an issue with the wire hook ups on the console, track problems, or motor may be going bad.
Mine had one wire on the switch in the console that was coming loose. Fixed that and no more issues.
Old Jun 5, 2013 | 08:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Door glass needs to be fitted. The assembly instruction manual (AIM) has a page outlining how to correctly set the glass against the weatherstripping.
To Driver window problem
