Replace radio
Old Jun 11, 2013 | 09:07 PM
billp123's Avatar
billp123
7th Gear
Default Replace radio
I have a 1980 with a radio/cassette deck that I would like to replace with a modern radio/CD player. It turns out that the space the old one occupies is not very popular because it is not a single or double din space. I believe I can install a single din but there will be an opening either above or below the new radio. What is the solution?
Old Jun 11, 2013 | 09:45 PM
sweeet76's Avatar
sweeet76
I believe you can get a large cover plate to cover the excess space then snap the radio face place plate over it. I also believe if you do a search, you might find some more info. Good luck with your project.
Old Jun 12, 2013 | 12:29 AM
Yellow1980's Avatar
Yellow1980
Check this out:
http://www.californiastingrays.us/Ar...tts/Radio.html
Old Jun 12, 2013 | 12:23 PM
78SilverCam's Avatar
78SilverCam
Just so happens....
http://forums.corvetteforum.com/c3-g...e-savings.html
Old Jun 12, 2013 | 12:32 PM
C3 4ME's Avatar
C3 4ME
probably all the suppliers sell a center gauge cluster housing with the DIN size opening made into it, then you don't have to go hacking up your original dash cluster.
To Replace radio
