Tarns serial number
Old Jun 12, 2013 | 10:42 PM
CORVETTEJOSE3's Avatar
CORVETTEJOSE3
Default Trans serial number
CAN SOMEONE TELL ME WHERE I CAN FIND THE SERIAL NUMBER ON A 4 SPEED TRANS ON A C3 TO SEE IF IT'S ORIGINAL TO THE CAR.
THANKS
JOE
Old Jun 13, 2013 | 02:01 AM
Bagpype's Avatar
Bagpype
It is on the drivers side near the top. There will be a couple numbers. One of them should match the vin and the other tells you when it was made and what shift it was made. If the numbers dont match, the number on the passenger side should tell you with a little research what it came out of. And please, for the love of god, take your caps lock off. It's like talking to someone who just screams at you.
Old Jun 13, 2013 | 09:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What model year. The location could vary. The assembly instruction manual (AIM) shows where it is supposed to be.
Old Jun 13, 2013 | 01:35 PM
Big Block Dave's Avatar
Big Block Dave
If my memory is correct, I think the numbers on my muncie were on the passenger side, where the main case and tail are joined, and its only a partial vin, like the last 6 or 8 or something like that.
Old Jun 13, 2013 | 01:39 PM
Bagpype's Avatar
Bagpype
On my borg Warner it's on the drivers side.
Old Jun 13, 2013 | 02:34 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
On your '69 Muncie, it should look like this:
The serial number is the VIN derivative, made with the same stamp that was used on your motor. It is on the side of the main case. I can't remember if it is driver or passenger side.
To Tarns serial number
