Dash gauges not working?
Old Jun 15, 2013 | 10:32 AM
chaz069's Avatar
chaz069
Default Dash gauges not working?
Had the center gauge console out recently. Replaced oil pressure line. Don't know if clock was working but temp, alternator,fuel, are not. The center cluster is a bugger to remove and reinstall. Any suggestions???Thanks again chaz069
Old Jun 15, 2013 | 10:55 AM
jso789's Avatar
jso789
Try cleaning the contacts on the connector plug on the back of the console. Also check to make sure its properly inserted into the slot. Sounds like a bad ground and/or connection if most of the gauges are not working. I agree it was a bugger indeed when I had to remove my center cluster to replace the light bulbs
Old Jun 18, 2013 | 08:40 AM
chaz069's Avatar
chaz069
Thanks I'll try it. I don't enjoy taking it out. Chaz069
Old Jun 19, 2013 | 08:41 AM
REDRAG's Avatar
REDRAG
Cruising
Default Gauges Stopped Working
I am having the same type of issue. All gauges seemed to be working last year and early this year; except the clock. Now, none of them are working. I will use suggestion to check connections, yet wonder if I have something different going on.
Old Jun 21, 2013 | 04:15 PM
chaz069's Avatar
chaz069
Default Dash gauges, clock not working
Move the thumb screw for setting the time. If clock starts working, it is a connection problem, intermittent ground etc. chaz069
Old Jun 21, 2013 | 05:44 PM
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
Here is a link to a recent thread I started about gauge issues. Unfortunately, I wasn't able to solve my issue, as the diagnostics recommended started exceeding my toolbox and talent-level, but there is a lot of good information in the thread that may be helpful to you:
http://forums.corvetteforum.com/c3-g...s-on-81-a.html
Good Luck!
Old Jun 21, 2013 | 09:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What are the gauges reading with the key on.. This is always my first question and can usually point us in the right direction...
Willcox
Old Jun 24, 2013 | 12:32 PM
chaz069's Avatar
chaz069
Default Gauges not working
When key is on or off gauges are inoperative. Fuel, amp, and temp, no movement. Clock arm will begin to move if you use the thumbscrew to adjust. Wiper will cycle once and hideaway door will close, will not stay running. Use of override **** under column, hideaway door cycles once and closes. There is power to all fuses, both input and out. chaz069
To Dash gauges not working?
