Finally got the new motor running good. I removed the computer from my 81 when I installed the new crate motor and was wondering if I could now remove the rubber hoses coming from the charcoal canister to the carb? Could I just remove the rubber hoses and plug the ports on the carb that the hoses went to or are the hoses still needed even though there is no more computer? TIA I am just trying to clean up the engine bay a little.
I recently found that the hose from my canister to carb had degraded and was not even attached to the carb. I even had to look up what the hose was and where it went to.
I replaced the hose and connected it to the carb and canister.
I can only say it made no difference at all in performance. How ever the tank still needs to vent instead of removing it and plugging the vacuum port I just decided to leave it connected.
All anecdotal but I don't think it will hurt to cover the port.
Quack has a point. I don't have a garage so it didn't occur to me.
My shed always smells a little of gas anyway. But, like I said I just want to make the engine bay a little neater. I got myself a small oven and a powder coating set up from Eastwood and am starting to powder coat some of my components. I do not even know how the charcoal system works and do not care. Just want my new engine to look a little neater. Thanks guys for all the input.
Would keep it, just use a braided line on it and the pcv if you want to dress it up. Mine got disconnected at roadside inspection by a Min of Environment cop trying to impress a newby he was training. The smell of gas on the drive home was awful.
...I just want to make the engine bay a little neater...I do not even know how the charcoal system works and do not care. Just want my new engine to look a little neater...
Taking the engine out frees up a lot of space in the engine bay, and then you don't have a bunch of nasty wires and hoses to worry about cluttering things up.
Never mind weight savings and huge reductions in fuel consumption.
