1977 High Speed Wipers
Old Jun 18, 2013 | 04:48 AM
speedau's Avatar
speedau
3rd Gear
Default 1977 High Speed Wipers
I'm just finishing a ground up rebuild on a 1977 c3 that was in a 1000 pieces when I bought it.
I have low speed wipers working ok by turning the indicator stalk 1 click forward. And when I push the stalk in the washer pump works.
How do I get high speed wipers??
I have tested the wiper motor and it can do high speed ok.
Old Jun 18, 2013 | 10:48 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
My guess is that you have an issue with the dreaded 77 wiper switch. The reason I say this is for the motor to run on low, both the black and light blue wires must be grounded. When you remove the black ground, the motor should run on high speed.
I would maybe go to the switch connector and make sure all the terminals are making good contact!
The switch ground is good because none of the functions would work if it wasn't. It's probably the switch as bad as I hate to say it... Test the wires and see what is happening at the switch connector.
Here is a simplified schematic I just made... It was the only one I didn't have completed yet so I went ahead and finished it this morning.
Old Jun 18, 2013 | 12:51 PM
1976wanderlust's Avatar
1976wanderlust
On my 1976, I had to make sure the switch was grounded.
Old Jun 18, 2013 | 02:58 PM
speedau's Avatar
speedau
3rd Gear
Thanks for the info but can you tell me what I need to do with the wiper switch to turn on high speed wipers?
The switch only feels like it only wants to turn forward one click. Should it turn further for high speed?
Old Jun 18, 2013 | 09:14 PM
0Willcox Corvette
Former Vendor
Hum.. Honestly this is not an easy fix.. not to mention the part is discontinued that would fix it.
Yes the switch should click forward another click for high speed.... You didn't say in your first post you only had one click.
There is nothing I can do for you except tell you to tear apart the column and remove the switch to see what is causing the issue and that is not an easy project.
Willcox
Old Jun 18, 2013 | 10:31 PM
speedau's Avatar
speedau
3rd Gear
I had a quick look at my column this morning before work and I think my problem is the cheap re-po lever I have installed.
It looks like I have the same problem as found earlier by these guys http://forums.corvetteforum.com/1579967350-post7.html
The drive pins in the lever are positioned incorrectly and therefore stop the lever turn to the second position.
Thank for your help much appreciated.
To 1977 High Speed Wipers
