Another C3 Puzzler
Old Jul 9, 2013 | 11:34 AM
mk's78's Avatar
mk's78
Default Another C3 Puzzler
I have another C3 Puzzler question...I was doing some underbody cleanup and noticed the pan attached to the underside of the transmission has a small hole at the bottom exactly at the 6:00 position.....and it is not plugged......
Can someone enlighten me as to what the reason for the hole is....and should it remain unplugged??????????
As always thanks for your patience and terrific help...
Mike's 78SA
Old Jul 9, 2013 | 11:59 AM
7T1vette's Avatar
7T1vette
That is the bellhousing inspection cover. The little hole at the bottom is a "drain" for any oil leaks that may occur in that area (transmission front seal; engine rear main seal; etc.). If you plugged off that hole, the oil would just collect until it leaked out the [un-sealed] seams on that cover.
P.S. We know that you are 'excited' about this issue. But, you really don't need to raise your 'voice'. {bold type indicates that you are yelling your question/response}
Old Jul 9, 2013 | 12:09 PM
Red 69's Avatar
Red 69
Mike's 78SA
Mike, I have a 79 L82 model with a TH 350 trans and have have removed trans and pan several times. That part was not made with a hole, plugged or unplugged from GM. If you can put your finger into it and find no plug, the trans cannot hold fluid and not drive the vehicle. If the car drives, you don't have a problem. A photo of what you are looking at would be helpful, as a 6 o'clock orientation is vague without a 12 o'clock orientation.
A previous owner might have drilled a hole to drain trains fluid, but then a plug would have been added. Sometimes a hole is also made to add a temp sensor to monitor trans fluid temp.
Old Jul 9, 2013 | 12:15 PM
7T1vette's Avatar
7T1vette
Inspection cover...not the oil sump pan.
Old Jul 9, 2013 | 12:55 PM
Red 69's Avatar
Red 69
Thanks for clarifying that, sounded like the trans pan to me and not the inspection cover under the flex plate. This hole seemed to explain itself.
Old Jul 9, 2013 | 02:35 PM
qwank's Avatar
qwank
no, that's caps lock
Old Jul 10, 2013 | 07:28 AM
mk's78's Avatar
mk's78
Default C3 Puzzler
Hi Red 69......It is not the trans pan with the hole as my 78 TH 350 did not have a drain hole for that year.....It is the pan towards the rear of the trans pan...BTW..Thanks for your input.....Mike
Old Jul 10, 2013 | 07:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Can someone enlighten me as to what the reason for the hole is...
It's a drain.
...should it remain unplugged?...
Yes.
What's up with the bold print?
Old Jul 11, 2013 | 12:02 AM
Scottys78's Avatar
Scottys78
this took a random turn
Old Jul 11, 2013 | 11:23 AM
scrappy76's Avatar
scrappy76
Pan towards the rear of the trans pan ?
Old Jul 11, 2013 | 06:10 PM
imariver's Avatar
imariver
To Another C3 Puzzler
