Front fender not aligning
Old Jul 14, 2013 | 07:29 PM
ONeill202's Avatar
ONeill202
Default Front fender not aligning
1970. My front fender never fitted correctly so today I finally had enough and decided to see what's behind the problem. That's when things started to go bad because the more I dug the worst things got.
I knew my front left fender had bodywork done, but I didn't know a plastic strip and styrofoam was part of the repair.
At this point I have a large gap between the door and the body. I'm not sure what is missing??? I looked at the images on the following site http://www.corvette-restoration.com but I'm still not clear what exactly is missing.
Here are a few images:
I'm not a body person so any assistance will be greatly appreciated...Thanks.
Al
Old Jul 14, 2013 | 07:52 PM
Roco71's Avatar
Roco71
It appears that someone has cut the corners off the top of the surround to repair the lower corner of the birdcage. It looks like they used some sort of foam to seal it up. Does the car leak?
Old Jul 14, 2013 | 07:54 PM
ONeill202's Avatar
ONeill202
Don't know. I've never had her out in the rain. She's a red head and doesn't like having her hair wet.
Old Jul 14, 2013 | 08:18 PM
Roco71's Avatar
Roco71
That piece of cardboard is replacing a sort of gutter that is missing. My guess is because it was rusted. What year is your car? To correct this mess you are going to have to remove the corners again and be prepare to weld.
I do not have a photo of the rust I cut out but rather the repaired corner. The White color is epoxy primer.
Old Jul 14, 2013 | 08:30 PM
ONeill202's Avatar
ONeill202
It's a 1970 and that seems identical to the problem I'm having. I noticed the black paint is that some kind of anti rust paint?
Old Jul 14, 2013 | 08:38 PM
Roco71's Avatar
Roco71
I used a Zinc Chromate primer under the black to prevent rust. It is what the factory used. Are you restoring this car?
Old Jul 14, 2013 | 08:42 PM
ONeill202's Avatar
ONeill202
Yes. It belonged to a man in Florida that has since passed away. He was an architect and wanted to restore a corvette as a retirement project. He did a lot of work but much still needs to be done. I haven't welded since high school so I'm sure to be rusty. Can you recommend a portable welder (mig) that I can purchase for this project?
Thanks for the help.
Old Jul 14, 2013 | 09:03 PM
Roco71's Avatar
Roco71
It looks like you have fairly fresh butyl tape around the windshield is it a new windshield? Did you do that or was it done? I am wonder about the condition of the W/S frame.
Old Jul 14, 2013 | 09:10 PM
ONeill202's Avatar
ONeill202
The windshield was replaced a few years ago. The installer noted on the receipt that surface rust was present on the frame. My plan is to remove the windshield next to inspect for rust. I maybe opening a bigger can of worms, but it needs to be done.
Old Jul 14, 2013 | 09:13 PM
Roco71's Avatar
Roco71
I used a small Lincoln mig that I bought years ago with C25,You can find them at places like Homedepot and Lowes it runs on 120.
Old Aug 3, 2013 | 06:31 PM
ONeill202's Avatar
ONeill202
I thought I'd share a few more pictures of the horrors I keep finding. Any chance someone might have the metal piece I need for this job? I'm not a metal worker and cutting all of this out of 16 gauge sheets of metal seems terrifying to me.
Old Aug 3, 2013 | 07:08 PM
champs65's Avatar
champs65
I think I have a good piece of the area you've pictured....let me check tomorrow and I'll let you know.
Old Aug 3, 2013 | 07:51 PM
ONeill202's Avatar
ONeill202
Originally Posted by champs65
i think i have a good piece of the area you've pictured....let me check tomorrow and i'll let you know.
Great!!! Thank you!!!
Old Aug 3, 2013 | 08:17 PM
Alan 71's Avatar
Alan 71
Hi ON,
The water that caused the rust you've discovered needed to go some where.
Hopefully it ran down the outside of the hinge pillar, but to be sure take a look at the BOTTOM of the hinge pillar through the kick panel area to be sure it's still solid.
Now's the time to know the truth.
Good Luck!
Regards,
Alan
Old Aug 4, 2013 | 09:45 AM
ONeill202's Avatar
ONeill202
Originally Posted by Alan 71
Hi ON,
Good Luck!
Regards,
Alan
Hi Alan:
Thank you for the reply. I've inspected the entire pillar area and it's truly amazing that there is no additional rust. There is, however, one more area of interest and that is along the rear of the center roof support. I've included a few pic below for your review and advise. I'd like to buy the metal that is needed for this area as well.
At some point some well intended person noticed all the rust and filled every crevasse with silicone caulking and styrofoam. It's been a dreadful job cleaning all the silicone out.
Thanks!
Old Aug 4, 2013 | 10:09 AM
Alan 71's Avatar
Alan 71
Hi ON,
If the hinge pillar is solid you're very fortunate.
The location where the center brace meets the steel halo looks like it will need some attention. There is some access from below but it looks like you MAY need to open it up from the top side too. It depends how serious it turns out to be and how thorough you want to be.
Regards,
Alan
Original appearance with no leak.
Old Aug 4, 2013 | 12:41 PM
ONeill202's Avatar
ONeill202
Hi ON,
Regards,
Alan
Thanks for the pic Alan -- very helpful. Looks like a gasket is required for this area, correct? Also, if you have other pics of the area that would help me even more -- thanks again.
Al
To Front fender not aligning
Old Aug 4, 2013 | 02:43 PM
champs65's Avatar
champs65
Sorry but I don't have a repair piece for you...it is the PASSENGER side that I have.
Old Aug 4, 2013 | 06:27 PM
lvmyvt76's Avatar
lvmyvt76
try a corvette salvage yard for this piece. It would help if we knew where you are located to suggest some.
Old Aug 4, 2013 | 06:36 PM
ONeill202's Avatar
ONeill202
I'm in Georgia but I'd go to the moon right now to find one. I've looked up and down the internet and still -- no luck. Thank you for your post I really appreciate the help.
