coolant tank
Old Jul 15, 2013 | 06:51 PM
AvRog's Avatar
AvRog
Default coolant tank
1969 427 coolant reservoir (or whatever). Should the connection to the rad not have a pickup shaft that picks up from the bottom of the reservoir??
Old Jul 15, 2013 | 07:31 PM
Mike Ward's Avatar
Mike Ward
If it's the OEM piece, no.
Old Jul 15, 2013 | 08:24 PM
AvRog's Avatar
AvRog
I think it may not be. I have one connection from the rad to the expansion tank body. There is a cap on the tank and not the rad. the only other connection is an overpressure outlet below the rad cap. If this is not correct will it still function?
Old Jul 15, 2013 | 09:48 PM
Mike Ward's Avatar
Mike Ward
The OEM piece is a copper 'tube' painted black with an inlet and outlet. It acts as an expansion (surge) tank and NOT a coolant recovery (puke_ tank.
Post a pic if you can.
Old Jul 16, 2013 | 05:36 PM
corvetteload's Avatar
corvetteload
The 427 with A/C is a different tank, Mike above is describing that tank.
Old Jul 17, 2013 | 08:12 AM
AvRog's Avatar
AvRog
No AC on mine, that's the way it was originally purchased. That's not to say tat the correct tank is there now. I'll try to post a pic.
Thanks Load and Mike
To coolant tank
