Almost Ready To Give Up
Old Jul 20, 2013 | 06:50 PM
gr8t73's Avatar
gr8t73
Default Almost Ready To Give Up
Unless someone on this forum can help me I afraid I might have to live with this. I've tried every adjustment I know of & have read numerous postings & articles regarding adjustment of the headlight pods but nothing seems to work. The attached photos are the best I've been able too achieve for the closed position & as you can see the front needs to come down another 1/4". I am hoping someone can tell me what I am missing.
Old Jul 20, 2013 | 06:58 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Have you checked the frame tha supports the headlight assmebly? Make sure that it is not broken or the light will never sit correctly.
Old Jul 20, 2013 | 07:02 PM
jnb5101's Avatar
jnb5101
try adjusting the length of the actuator bolt. if it's too far extended(threaded out too much) the vacuum can will bottom out and prevent full movement(either up or down).
Old Jul 20, 2013 | 07:03 PM
champs65's Avatar
champs65
What year? I'm guessing a 73 based on your username.
Maybe you have a pair of headlights that don't belong on the car....I think there is a difference in size, mounting and/or adjustment on the newer headlights (74-up?) that don't work correctly on the older C3s (and probably vise-versa).
(I see the pic now)
Old Jul 20, 2013 | 07:25 PM
mds3013's Avatar
mds3013
In the center of the linkage there is a 1/2 in. bolt head that is accessible from underneath the assembly. This is the fine adjustment for the height of the leading edge of the door. Is this an adjustment you have tried? Since the back of the door is at correct height jnb5101 may be correct. mike...
Old Jul 20, 2013 | 07:33 PM
kdf1986's Avatar
kdf1986
The headlight assembly also is supported by a U shaped frame. That is attached to the front area by several bolts. Putting shims between the frame and the U shaped assembly can also move the headlight assembly down.
kdf
Old Jul 20, 2013 | 09:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Have you watched the video on this that I did?
You might be able to take the pivot screws loose on the side and pick that distance up... I'm not sure.
Here is the video link.
Headlamp Housing Adjustment 68-82
Old Jul 20, 2013 | 10:45 PM
gr8t73's Avatar
gr8t73
Mounting frame is solid.
Old Jul 20, 2013 | 10:47 PM
gr8t73's Avatar
gr8t73
I've threaded the Clevis as far down onto the rod as it will go.
Old Jul 20, 2013 | 10:50 PM
gr8t73's Avatar
gr8t73
(I see the pic now)
Yes it is a 73 & these are the original headlights.
Old Jul 20, 2013 | 10:53 PM
gr8t73's Avatar
gr8t73
kdf
The headlights mount on top of the front support bar adding shims at this point will make the headlights set higher in the opening.
Old Jul 20, 2013 | 10:56 PM
gr8t73's Avatar
gr8t73
This is Avery informative video & I used it to get the headlight as close as it is. It just seems I've run out of downward adjustment & I am at a loss as to why.
Old Jul 20, 2013 | 11:09 PM
gr8t73's Avatar
gr8t73
I should have stated this in the original post as I think it is a key point. If I disconnect tne Clevis I can adjust the headlight to the proper height so obviously the stroke of the actuator is too short. As I stated I have threaded the Clevis as far down on the actuator rod as possible but it is still too long. The headlight opens properly & locks into the open position.
Old Jul 21, 2013 | 12:16 AM
gator79's Avatar
gator79
not the proper fix but could you shim the actuator back some?
Old Jul 21, 2013 | 02:09 AM
speedreed8's Avatar
speedreed8
replace the actuator
Old Jul 21, 2013 | 08:19 AM
Dave J's Avatar
Dave J
This should be a piece of cake. I had the exact issue when I rebuilt my assemblies. Check back to the Willcox video. At 6:40 time frame, there is a slotted bracket held onto the underside of the headlight lid and attached by three bolts. This must be adjusted to about center of the slot the bolts fit into.
Proper adjustment; With the actuator disconnected, and the headlight bucket fully open and locked, apply vacuum to the front of the actuator. The actuator rod should fit into the forward end of slot in the connecting link extended position. If you cannot do this, or you have to push the actuator rod into the actuator to connect it, the slotted three bolt bracket is out of adjustment.
I have a '70, and this came from the chassis service manual. There is a section on "Headlight Panel Adjustment". Your car should be the same. Good luck.........
Old Jul 21, 2013 | 08:57 AM
carjack007's Avatar
carjack007
Hi gr8t73,
I recently replaced my actuators with new aftermarket ones. After trying everything I could they would not close all the way...just like yours. I finally cut 1/4" off the end of the actuator rod and that solved the problem. If you did not change anything and they did close properly before, then you have an adjustment problem.
Bob
To Almost Ready To Give Up
Old Jul 21, 2013 | 09:04 AM
SS164's Avatar
SS164
Try adjustment bolt shown in photo. You can adjust bolt on either end.
Open assembly fully and reach in from bottom or remove grille.
Good luck.
Old Jul 21, 2013 | 10:51 AM
fadingrockstar's Avatar
fadingrockstar
This is why I love this site. Someone has a problem and everyone jumps into help. I don't have any advice to offer, it's just nice seeing the help.
Old Jul 21, 2013 | 11:27 AM
Dave J's Avatar
Dave J
[QUOTE=SS164;1584461743]
The 3 bolt U shaped bracket is pictured above. It's the one below the rod bellows. You lengthen the travel of the actuator rod by adjusting the bracket farther towards the front of the car.
