side vents
Old Jul 21, 2013 | 07:50 AM
SB64's Avatar
SB64
Default side vents
I noticed that some 68/69 vettes have only 3 side vents with 1 blocked, others have all 4. Why????
Old Jul 21, 2013 | 08:53 AM
champs65's Avatar
champs65
As far as I know, all 68-9 cars should have that last vent blocked. The area behind it is part of the body/firewall.
Bubba might have decided everything would cool better if the fourth was cut open
Old Jul 21, 2013 | 11:09 AM
SB64's Avatar
SB64
Default side vents
ooh good thing I didn; join the bubba squad. thanks for the heads up
Old Jul 21, 2013 | 11:21 AM
DZRick's Avatar
DZRick
Are you sure the ones you've seen that you thought were cut out weren't just correctly painted black to look like the others that are cut out?
I find it more common that like myself owners haven't blacked out the fourth vent and instead left it body color.
Blacking mine out is on my to do list.
Old Jul 21, 2013 | 11:49 AM
gbvette62's Avatar
gbvette62
The 4th louver was never cut out. The area behind it, does not open to the engine compartment. It actually seals the plenum area of the cowl, where fresh air is fed to the interior.
You don't want to open it up. As DZRick said, paint it flat black, as it originally was.
Old Jul 21, 2013 | 08:54 PM
Lupigiato's Avatar
Lupigiato
I dont understand why so many repainted 68/69 Vettes are not done correctly. I had to black out mine.
Old Jul 22, 2013 | 12:11 AM
7T1vette's Avatar
7T1vette
Semi-flat black or satin black....not flat.
Old Jul 22, 2013 | 01:47 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Glad I read this. I just put a new one piece front end on my 69. All Louvers are cut out on the fenders including the rear slots. I was just going to leave them open but now sounds like I need to block them.
Terry
Old Jul 22, 2013 | 02:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by HOOAH
...Glad I read this. I just put a new one piece front end on my 69. All Louvers are cut out on the fenders including the rear slots. I was just going to leave them open but now sounds like I need to block them...
Check the AIM. There are bonding panels behind each of the rear vents which close them off. These panels are needed to mount the fenders at the cowl.
To side vents
