Help with bleeding brakes
Old Jul 23, 2013 | 08:13 PM
noonie's Avatar
noonie
Originally Posted by alconk
Yea it's crazy, the helper pushes down on the pedal and I open the bleeder and nothing??? I did power bleed it after that with the Motive and got alot of fluid out. I re did the whole system and to me it still just don't feel right.
Bad master
Well I know that's not the problem because I just bled the front master cylinder by using the plastic fitting with hose. I actually saw bubbles as my helper depressed the pedal. Yoou know what I mean where you take the hose and submerge it in the fluid. Same thing as bench bleeding but did it on the car.
No resistance, so no pressure needed.
Originally Posted by mds3013
Yes, I understand. If the MC is producing the required pressure then you should have pressurized fluid flow when you open the bleeders with helper pushing pedal. Either the MC is not producing the pressure or you have an obstruction. You should not be able to hold back the pressure from the MC while holding your thumb over the outlet hole with helper pushing on pedal. Sorry I can not offer more help. Frustrating when I can not get my hands on the car. mike...
You're missed mds3013's response.
Your master is probably bad, doesn't matter if it's new.
If you get flow with the Motive then the system is clear and full, including the differential valve, hoses, and the master pistons are relaxed.
You're simply not pressurizing the front circuit.
Probably nothing wrong with your calipers, talk to another shop.
Old Jul 23, 2013 | 09:56 PM
PeteZO6's Avatar
PeteZO6
My thoughts exactly. As soon as OP said he couldn't get fluid out of the front calipers when manually bleeding (but could with power bleeder) it sure says bad M/C.
Pete
Old Jul 23, 2013 | 10:04 PM
alconk's Avatar
alconk
Wow I paid extra bucks too to get a AC Delco unit. What do you guys think a good replacement would be or does it matter? Also what did you think about the fluid at each bleeder?
Old Jul 23, 2013 | 11:24 PM
PeteZO6's Avatar
PeteZO6
I'm not sure you have a genuine replacement master cylinder if it doesn't have bleeder screws on it. Corvette Stainless Steel brakes and Corvette Central both sell the correct master cylinders. Probably other vendors also.
Pete
Old Jul 24, 2013 | 02:10 PM
alconk's Avatar
alconk
Well I just went out to the car and gravity bled the calipers but just for a short time. At first I didn't have any fluid coming from the LF caliper then it started to flow. After awhile I closed the bleeder up and checked brake feel. Nice and firm so now for a test drive. I now have a firm pedal but it seems too firm if that's possible. I tried to lock up the tires but it wouldn't do it, I did this at different speeds. I don't know if this is correct or not. I did however order me the correct M/C, new bleeders and a set of stainless steel brake lines. The only way I was able to lock up the tires was in gravel and that was at low speeds but the back wouldn't lock up??
