temporary spare tire?
Old Jul 21, 2013 | 02:15 PM
oldC3guy's Avatar
oldC3guy
Default temporary spare tire?
When I bought my '78 the spare tire and tub were missing. I found a tub for sale but now I should try to find a spare. My manual says that the car came with a "temporary spare" size P195/80D15. Where would be a good place to find this item? Junk yard? I would like to get one with a new (or relatively new) tire. How have you all sourced this?
Thanks in advance.
Old Jul 21, 2013 | 02:22 PM
briankeery's Avatar
briankeery
My original was totally shot when I dropped the tub this spring. I just went to a tire shop and bought a good used 195/70R/15, fit in the tub perfectly. Not NCRS, but on the side of the road, I'm not gonna be too worried about that.
Old Jul 21, 2013 | 02:48 PM
zwede's Avatar
zwede
You can use a compact spare from a 4th gen Camaro/Firebird. They're cheap on ebay. 93-02 works with stock brakes, 98-02 also works with big brakes (13" rotors).
Old Jul 21, 2013 | 03:46 PM
alswagg's Avatar
alswagg
I don't carry a spare at all anymore. I store our luggage bags in the spare carrier. I do keep a can of tire sealer and pressurized air. We run many long distant road trips. Ie; 1500 to 3000 mile round trip cruises. Never had any issues. New tires and be vigal about air pressure. Al
Old Jul 21, 2013 | 04:09 PM
ddawson's Avatar
ddawson
Diameter needs to the same size correct? At least on the rear.
Old Jul 21, 2013 | 04:21 PM
mds3013's Avatar
mds3013
For the OP. What size tire are you running now? What wheel? The spare tub for a '78 was different than '68-'77. This was so that a 255-60-15 flat could be carried in the tub. I would get a similar wheel to what you are running and a tire of the same size. I have these on mine. Four on the ground and one in the tub. No need for a hard to find compact spare for yours. You will need a jack and tools to change the flat also. Have you looked under the pass. side storage compartment liner for those? mike...
Old Jul 21, 2013 | 04:46 PM
zwede's Avatar
zwede
No, it's ok to use a smaller spare on the rear as long as you don't go fast or leave it on a long time. Many newer cars with posis have smaller spares. I think I remember the owner's manuals warning about exceeding 50 mph if you mount it on the rear.
Old Jul 21, 2013 | 05:27 PM
gbvette62's Avatar
gbvette62
The 78 spare tire tub, is not different. The same tire tub was used in all 1968 to 1982 Corvettes.
The only difference with the 78-82 Corvettes spare tire tub, is the hangers to mount the tub. The hangers were changed to allow the tub to hang lower, when the temporary spare was replaced by a flat P255/60R15.
The original Goodyear P195/80D15 "Temporary Use Tire", is no longer available, and I don't know that anyone makes a regular P195/80R15 road tire either. The OEM tire had a diameter of about 27.5". Either a P195/70R15 or a P20575R15 should work, as they both have diameters in the 27.1" to 27.4" range. Both sizes are currently available, from an assortment of tire makers.
Old Jul 21, 2013 | 05:36 PM
mds3013's Avatar
mds3013
My mistake on the hangers being different and not the tub. Sorry about that. mike...
Old Jul 21, 2013 | 08:57 PM
blk79nj's Avatar
blk79nj
I may be wrong, but I thought that the gas tank increased from a 17 gallon in '77 to a 24 gallon in '78. To make up the difference in size, they went to the smaller spare tire. I never tried it on my '79, but I'm not sure a full sized tire will fit in the tub.
BTW, I pulled out my original spare tire, and filled it with air. It leaked all around tire bead.... so I just put it back up in there. If I have a problem, I'll just use my cell phone.
Old Jul 21, 2013 | 09:24 PM
gbvette62's Avatar
gbvette62
They did increase the size of the tank in 78, but that had nothing to do with the switch to the temporary spare.
The tank is bigger, but the rear of frame remained the same, as did the position of the underside of the tank. The size of the tank was increased on the top. Because of the 78-82's fastback body style, there was more space available above the tank, allowing GM to increase it's capacity.
The temporary spare was used, to help reduce weight. In the late 70's and early 80's, GM was doing all they could to reduce the car's weight, in an effort to improve fuel mileage.
Chevrolet was aware that cars like the 911 and Ferrari's, had no room to carry the full size wheel, if they had a flat. Chevy didn't want customers to have to put a muddy flat tire, in the interior, like Porsche owners did. They redesigned the spare tire tub's hanger hardware, to allow the tub to hang lower, if the 255/60 needed to be carried in the tub.
Old Jul 21, 2013 | 09:25 PM
68/70Vette's Avatar
68/70Vette
I think the stock steel wheel and tire weighs about 50 pounds. At 70 years of age, I think I've only done a tire change using the spare 2 times in my life. Once when I had a blow out on my 65 Mustang on the freeway and once on the 95 Cadillac in a shopping center parking lot. I plan to just rely upon AAA.
Old Jul 21, 2013 | 10:04 PM
blk79nj's Avatar
blk79nj
Cool, I learned something today. I guess it makes sense that if you had to change a flat tire, that you had a place to put flat one.
Old Jul 21, 2013 | 10:16 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Just got back from the local tire dealer Friday, had him get me a spare ( biggest that would fit in my 75s 27" tub ).
Since i am running monster rear tires ( P275/60s ) i was looking to get something in the same tire dia which is 28.06 but it wont fit in the tub.
Have never had a flat in the vette, just being prepared i guess.
To temporary spare tire?
