Fuel pump advice
Old Jul 25, 2013 | 06:52 AM
C3smallblock's Avatar
C3smallblock
Default Fuel pump advice
I have come to the conclusion that my 76 Vette's fuel pump is dead, so I went to the auto store and they sold me the "correct" one for my car, which looks right, but on getting it home, I notice that there is only one inlet and one outlet, where as the original on the car has two in and one out. Have I been sold the wrong thing, or is there a mod that I need to do to use this one?
Cheers
Kev
Old Jul 25, 2013 | 07:11 AM
Roco71's Avatar
Roco71
The pump should have a return line (the smaller of the two) I would return it and if they tell you that's the only one they show try elsewhere. I bought mine for my 71 (with return line) at NAPA.
Old Jul 25, 2013 | 10:34 AM
Ironcross's Avatar
Ironcross
not all fuel pumps are the same just as Corvettes are not the same.....good thing it was not a internet transaction...freight and possible different prices might apply.....some one didn't ask or supply the correct questions or answers as a result the wrong pump was purchased......take it back and exchanged it
Old Jul 25, 2013 | 12:58 PM
scrappy76's Avatar
scrappy76
Return it and get the right one.
Old Jul 25, 2013 | 01:21 PM
Peterbuilt's Avatar
Peterbuilt
The rubber lines between the tank lines and the fuel pump should be molded, if you use standard auto store hose it can kink and block fuel to the pump.
Old Jul 25, 2013 | 03:21 PM
C3smallblock
Thanks guys, I thought as much, but I am a repairs novice, so it always pays to ask people who know.
Cheers
Kev
Old Jul 25, 2013 | 03:37 PM
oldschoolvette's Avatar
oldschoolvette
Cheers
Kev
the correct pump should be readily available
just return it
Old Jul 25, 2013 | 03:40 PM
C3smallblock
One question that I was asked when I bought this pump, was if the thread to the carb was (3/8 or 5/16 I think were the two options). I didn't know, so I actually bought both, so that I could return the incorrect one. I have scoured the internet trying to find out what the thread is and I can't find it anywhere. Does anyone know?
Cheers
Kev
Old Jul 25, 2013 | 04:07 PM
Roco71's Avatar
Roco71
I know the fuel line is 3/8th and the return line is 1/4th I am not sure about tread size. There should be a 90 degree brass fitting on your original pump you will need that fitting on your new pump. See which pump it fits.
Old Jul 25, 2013 | 04:11 PM
C3smallblock
Actually he did say the fuel line, I must have presumed he was talking about the thread. I have never done anything mechanical like this before, but I want to start learning, so I really appreciate all the advice and support.
Cheers
Kev
Old Jul 25, 2013 | 04:13 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I got a direct fit one for my car, definitely good to get it local, in case there are fitment issues, flaws etc
Old Jul 25, 2013 | 04:22 PM
Roco71's Avatar
Roco71
I am not trying to add to your list but I would replace the two rubber fuel lines that go from the pump to the hard lines on the frame. The 3/8th line is a "S" shape to prevent it from kinking. They can be bought from several supporting vendors.
Old Jul 27, 2013 | 10:49 PM
SciVette's Avatar
SciVette
Fuel pump replacement was the first major repair on my Vette as well: http://forums.corvetteforum.com/c3-t...fuel-pump.html
I'm still a newbie at turning wrenches, but it went well and gave me confidence to begin tackling other jobs... Good luck with your repair.
Old Jul 28, 2013 | 12:42 AM
TimAT's Avatar
TimAT
The "out" fitting is a 3/8 inverted flare. Some cars had a 90* fitting in the pump that had both a male that went into the pump and a female the line to the carb went into.
To Fuel pump advice
