Drive belts?, Pollution control deleted.
Old Aug 1, 2013 | 09:08 AM
dewm1's Avatar
dewm1
Default Drive belts?, Pollution control deleted.
Hi folks, my '79 L48 has had the pollution control pump removed. When I bought it, all the belts are adjusted max to the end, they're old, cracked and stretched out I'm sure. I've looked for numbers on them and cannot make them out.
Can anyone tell what belts, alternator, power steering, A/C I need to buy so when they're adjusted tight enough when new, they're not at the end of the adjustment arms?.
Many thanks!
David.
Old Aug 1, 2013 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Most of the generic auto parts places can look up the belts you need. The vendors here on the forum also carry them. If memory serves, the AIR pump belt is separate.
