Dash pad skin,overlay ?
Old Aug 5, 2013 | 09:35 PM
Freddy76's Avatar
Freddy76
Default Dash pad skin,overlay ?
Has anybody have any luck with the dash pad skins ? I know it's a cheap way out, but it's a cheap alternative for now.
Old Aug 5, 2013 | 09:52 PM
oledave60's Avatar
oledave60
My original dash was as bad as it could get. I did the dash skin and it turned out great . It is not just a skin, but a thick over-lay that glues to the original dash. I used strips of wood above and below and a bunch of clamps. It turned out very good.
Old Aug 5, 2013 | 10:02 PM
markids77's Avatar
markids77
I bought a used hard plastic overlay for my 77 from a member here. I removed the dash and did like oledave says... construction adhesive and paint stir sticks and c-clamps to distribute the clamping force. Dyed with VHT spray dye and it looks almost factory. I am very happy with how it turned out, and I have less than $50 in the whole deal.
Old Aug 5, 2013 | 10:05 PM
7T1vette's Avatar
7T1vette
The dash 'cover' is thicker and lays on top of the dash. The dash 'skin' is just thin vinyl that replaces the outer surface of the existing dash. I didn't think any vendor still sold the dash 'skins', anymore.
I re-skinned my inner door panels several years ago. They didn't turn out like 'new' panels, but for 1/5th the money, they were an 8 out of 10. But....they were a real P.I.T.A.!!! I would never do that to myself again.
The upper dash would be much easier to re-skin (if skins are still available), however. The difficulty would be getting the dash pad out of the car undamaged; reskinning it to acceptable condition; then reinstalling it without damaging it. I'm not sure that doing all that is worth the price difference, but if it worked, you can legitimately claim [as I have] that your dash is still the 'original' piece.
Old Aug 5, 2013 | 10:34 PM
Freddy76's Avatar
Freddy76
Can I reskin the dash while still installed in the car ?
Old Aug 6, 2013 | 01:02 AM
desue's Avatar
desue
would like to see pics if anyone has them, this is something I'm considering myself
Old Aug 6, 2013 | 10:05 AM
oledave60's Avatar
oledave60
Here is my 75. As I stated earlier, my dash was in very bad condition. It had a big crack in the middle and I had to re-enforce it from underside with some alum flashing and rivets.
The new cover was a very good fit, but I did have to trim each end of the old dash to get a better fit.
A tube of glue comes with it, but I used three tubes. The dash was from Corvette America.
This is the underside patch.
Old Aug 6, 2013 | 10:10 AM
Freddy76's Avatar
Freddy76
The overlay I'm looking at is on page 219,in the Corvette America catalog. They call it a dash shield.
Old Aug 6, 2013 | 10:15 AM
Freddy76's Avatar
Freddy76
That's a great looking job. Nice interior. My dash is horrible. The speaker holes are non existent. I was going to wait till the winter to do it,but I can't stand looking at anymore.
Old Aug 6, 2013 | 10:20 AM
gdh's Avatar
gdh
I saw Mooser's dash overlay, I would not have known if he hadn't told me.
Old Aug 6, 2013 | 11:00 AM
Mooser's Avatar
Mooser
My original dash had several cracks through / around the speaker holes and looked bad from the outside.
The one I put on was just the skin, same as 7T1's, basically the thin sheet of vinyl formed to the right shape (well close, took several hours with a heat gun to get it to fit nice) used a small hole punch to re-punch all the speaker holes back through.
PIA but worked well enough. Don't think they still sell them. Can't be done in the car.
M
Old Aug 6, 2013 | 04:18 PM
7T1vette's Avatar
7T1vette
Knowing what I do about "re-skinning" interior panels.... That is one fine job there, Mooser!!
Old Aug 6, 2013 | 08:26 PM
Freddy76's Avatar
Freddy76
That looks great. Was it hard to get the dash out?
Old Aug 6, 2013 | 09:15 PM
Mooser's Avatar
Mooser
Dash removal on these has never been fun, pretty straight forward but you need to start by removing the tail-lights, well almost
here's a thread that has a decent breakdown
http://forums.corvetteforum.com/c3-g...move-dash.html
oledave60, that looks like a great job, was that a skin or one of those shields?
M
Old Aug 6, 2013 | 09:17 PM
oledave60's Avatar
oledave60
Well, I hate to tell you this, but I got mine out and back in without the windshield. I have read that it is very difficult to get out or in with the windshield in place. Good luck.
Old Aug 6, 2013 | 09:21 PM
oledave60's Avatar
oledave60
Mooser, It was a shield and with a bit of trimming to the old dash it fit very snug and I am very pleased with it
I wish I could same for the door panel "skins". They are less than good.
Old Aug 6, 2013 | 09:23 PM
markids77's Avatar
markids77
Did mine with the windshield in place, but reinstallation is a bit fiddly. I had previously removed all the lower dash components as well as the steering column so it went as smoothly as possible. Be careful as you set it back in to get the side to side spacing as even as possible so your a-pillar trims will go back in all the way without needing to be trimmed repeatedly... ask me how I learned that!
Old Aug 6, 2013 | 09:29 PM
Mooser's Avatar
Mooser
My windshield was also in place but everything else was out.
Pick a good warm day since you'll need to flex the dash somewhat to get it in or out.
M
Old Aug 8, 2013 | 08:44 PM
Freddy76's Avatar
Freddy76
All good ideas. Thanks guys for your input and expertise.
To Dash pad skin,overlay ?
