tail lights out
Old Aug 5, 2013 | 10:12 PM
GarthVader's Avatar
GarthVader
Default tail lights out
Last night as I was driving home when my indicators stopped flashing. As I went to pull into my driveway flashing lights in my rearview alerted me to a the Police following me into my driveway. I can't call it pulled over because I was in my driveway, but the police officer notified me that my tail lights, indicators and brake lights were all in op. No ticket, just a warning to get the car fixed. This afternoon I changed all the fuses and I recently changed the flasher within the last few months. Still not working. So my question is to the Corvette Forum Gods, any ideas other than some faulty wiring which I really hope is not the case?
Old Aug 5, 2013 | 10:23 PM
72LS1Vette's Avatar
72LS1Vette
Most likely your turn signal switch broke if everything stopped working at the same time. Not a difficult repair but one that will take a couple of hours and a rental tool from your local AutoZone.
Rick B.
Old Aug 5, 2013 | 11:34 PM
GarthVader's Avatar
GarthVader
Thanks Rick. I'll be looking that up in my Chiltons tomorrow.
Old Aug 6, 2013 | 01:20 AM
mrmagrath's Avatar
mrmagrath
Same happened to me. Turns out it was the plug on the lower steering column that had worked loose. Looked like it was still connected though.
Old Aug 6, 2013 | 06:51 AM
The Punisher's Avatar
The Punisher
Same here the wire harness came loose, check that
Old Aug 6, 2013 | 07:37 AM
GarthVader's Avatar
GarthVader
I checked that already but I'll give it another shot. Thanks for the tips guys.
Old Aug 6, 2013 | 11:43 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a simple schematic. Hope this helps..
It sounds as if you have two problems if the tail lamps and the brake and turn signals. are not working at the same time. The only thing in common with the two issues is the ground rear ground.... and the rear harness connector.
I would check the grounds at the housings first. Then I would go to the wires Brown for the tails, Yellow and green for the brake lamps and test for power. If you have power at the back then chances are the issue is ground...
If you don't have power, work your way forward to the rear harness connector, make sure the leads are not corroded and test there for power. Then go to the turn signal switch and so on.
Old Aug 6, 2013 | 01:46 PM
GarthVader's Avatar
GarthVader
Great info. Thank you very much for the suggestion and the schematic.
Old Aug 6, 2013 | 04:03 PM
7T1vette's Avatar
7T1vette
Broken power feed wire or bad ground connection at the rear of the car.
P.S. A 'broken' wire does NOT have to be separated. The [internal] wire can be bad, but the insulation still intact.
Old Aug 7, 2013 | 07:58 AM
GarthVader's Avatar
GarthVader
I looked for all of these and I wasn't able to find anything. Now the plot thickens. The car now doesn't want to shut off. When it rains, it pours. Thanks for all of the suggestions guys. I'm going to keep looking this afternoon.
Old Aug 7, 2013 | 08:31 PM
0Willcox Corvette
Former Vendor
Go to the plug for the turn signal switch.. Pull it off and check to see if you have any burnt corroded or odd looking wires. But that still doesn't explain the other tail lamps not working if this is the issue. You may have more than one issue.
Everything in the column passes though this connector.... Ignition switch, turn signals, and so on.
Old Aug 8, 2013 | 11:51 AM
GarthVader's Avatar
GarthVader
I did it and the no corrosion or burning evident. I'm probably going to have to put the car away now because I have to leave at the end of the month for a few months. I have a lot of preparations to do before I leave. When I get back, it will not be the ideal time to drive a Corvette in Buffalo, NY. Thank you very much every much for all of the suggestions and information guys.
Old Aug 12, 2013 | 06:24 PM
GarthVader's Avatar
GarthVader
Thanks for all of your help guys, I found the culprit. Just in time too. My DD is in the shop and I didn't have a ride to work tomorrow. Now I do, and in style.
Old Aug 12, 2013 | 07:49 PM
loup68's Avatar
loup68
Army
What was the problem? Please tell us. Lou
Old Aug 12, 2013 | 08:13 PM
mrmagrath's Avatar
mrmagrath
Yeah! What's the deal?
Old Aug 13, 2013 | 10:20 AM
GarthVader's Avatar
GarthVader
There is a ground wire that runs from the frame and the exact spot wear the antenne ground attaches to the frame. From there it attaches to the drivers side brake/reverse light. That wire was broken at the light terminal. I wouldn't have known it if I hadn't seen a picture that Alan had posted in another thread. Oddly enough, with this ground broken and the brake pedal pressed, my car wouldn't shut off either. The picture is in this thread. http://forums.corvetteforum.com/c3-t...ghts-help.html
To tail lights out
