*** Date codes ***
When the factory was assembling engines, was it possible to have parts that were cast a couple of days before being attached to the engine. I have a 215 head with a date code of I 19 7 (Sept. 19/67). Engine built on Sept. 21. Other head casted H 2 7 (Aug. 2/67). Thanks in advance for your opinion.
Mike, that's even a stretch for your imagination.
When the factory was assembling engines, was it possible to have parts that were cast a couple of days before being attached to the engine. I have a 215 head with a date code of I 19 7 (Sept. 19/67). Engine built on Sept. 21. Other head casted H 2 7 (Aug. 2/67). Thanks in advance for your opinion.I too thought they were too close for comfort until reading you post.
Ill have to sit down and get them all together , then we'll confer.
Sounds like our cars weren't to far apart on the line.
Did you get my PM with email.?? this morning.
By the way,, what's your Block dating....??
Marty,....
Marty,....
If nothing else, this sort of info (easily available at the dreaded other place) keeps some people with blue cars amused.
The distance at Flint was a half hour drive IIRC and there was a fleet of dedicated trucks moving stuff almost non-stop.
Wonder if the blue car guy is still laughing?
Now, could an NCRS person contrive a scenario in which that can actually occur SO THAT HIS CAR CAN BE VALIDATED AS A [POSSIBLY] FACTORY-ORIGINAL VEHICLE? Sure. That's what someone with a 'special interest' would want to happen.
No one with any familiarity with GM plant operating systems and metal fabrication would be goofy enough to believe this could happen. But, if the dogma states that any date earlier than the vehicle build date is viable, that MUST mean that it's the absolute TRUTH...
These are the kind of things that go on which prevent me from having any interest in the NCRS organization. "Legitimacy" of a vehicle is decided by some "expert" in the organization and then perpetuated ad nauseum "because he said so"....rather than just setting some basic standards and then appreciating the many Corvette cars for what they are.
While I think of it, there's a post on the other site written in November 1998 by Al Grenning describing how it was possible for castings to end up in finished engines in such short time periods. This set of circumstances was confirmed by a former GM plant employee named Phil Hawkins who separately described why some castings also sat around for months.
That makes two different guys that were 'there in the day' who confirmed how and why. The independent modern day research by Al Grenning to find out why so many 1-2 day spreads showed up on undisturbed cars is typical of his thorough investigative work.
Coming from a manufacturing background myself, I can identify with the logistics that were involved 'back in the day' that caused such variability.
Does that convince me that it could actually occur? No, not for a heartbeat. Hidden agendae get "proved" all the time...by whatever means are necessary.
http://forums.corvetteforum.com/1584695447-post21.html
Ya right.
Let's consider two factors
1) NCRS doesn't judge date codes on heads at all. They're underneath the valve covers which are not removed.
2) NCRS doesn't authenticate any component of a car as being 'the original born with' piece.
So there would be no incentive or benefit for a member to invent a story about date codes or engine assembly process.
Also- the OP and the other gentleman in this thread whose cars have close dates have not (yet) been through the judging process or been otherwise desecrated by the evil NCRS. Add this to the hundreds or thousands of cars that have been noted over the years to similarly have close dates.
I wonder how this can be explained- who are all these people that choose close dates, why would they do so if it's controversial- and possibly most perplexing- where do they find these stack piles of parts that are dated so close? Seems to me that there would be an even bigger stack of components that are dated much more realistically, up to six months older than the assembly date let's say. If I were building a clone car to fool someone, the LAST thing I'd do is make fundamental mistake with obvious stuff like this.
But there again, I'm not very good when it comes to imagining conspiracy theories. I've misplaced my tinfoil beanie, so maybe my brain was reprogrammed while I was sleeping.
: Group Hug
