69 gas tank removal
Old Aug 23, 2013 | 11:22 AM
SB64's Avatar
SB64
Default 69 gas tank removal
Saw a thread on build sheet attached to gas tank. Did some gentle snooping with a piece of wire and there is a build sheet there. Car is already in air for trailer arms so is it a hard job to drop the tank to get that sheet. Is it just a cool thing find or what or has it some value????
Old Aug 23, 2013 | 11:54 AM
Socalrebell's Avatar
Socalrebell
When I restored my '69 I had a professional remove the gas tank, one thing I am sure of is make sure the tank is completely drained and free of fumes. I'm fairly sure (but not positive) only 2 straps hold it up. The tank sticker is an important part of documenting your car. It lists all the options, when it was built, where it was built, what dealer originally sold it. It is a wealth of knowledge and a must have if you are restoring it. I did a 3 year resto on my L71 (427/435) and this paper proved it was an original L71.
Old Aug 23, 2013 | 12:07 PM
martyr's Avatar
martyr
My '75 build sheet was found in the same place 2 years ago. It was caked in 37 years of dirt and grime so not all parts are legible but it is a very cool thing to have and an important document if you can see the good parts.
Old Aug 23, 2013 | 12:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I don't want to rain on your parade, but your tank sticker may not be legible when you finally get to it. It's been there forty years and has had plenty of time to be covered with road gook.
Good luck.
Old Aug 23, 2013 | 02:10 PM
Socalrebell
Good luck.
I lucked out, mine is a California car most of it's life, took the sticker off in 1994 everything is legible and it is mostly in one piece. I put it between 2 pieces of plexiglass for protection. You'll never know until you look.
Old Aug 23, 2013 | 07:39 PM
Socalrebell
Originally Posted by Faster Rat
Is your car original drivetrain? If not, don't worry about the build sheet. It no longer is what it used to be when it left the factory, so it doesn't matter.
If your car is original and you are restoring it...then you might as well drop the tank while you are at it and have a look. Mine was dirty, but I cleaned it with a makeup brush, took a bunch of high resolution photos, then covered it with a sheet of clear plastic sealed to the cleaned tank with duct tape. It belongs where it is.
That's exactly why I wanted my tank sticker 98% NCRS Top Flight Award and being a high optioned 427/435 and having the proof to back it up and every # matching is gold
Old Aug 23, 2013 | 07:48 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Nothing on these cars is easy. Everything you do takes more time and costs more money than you think it will.
Old Aug 24, 2013 | 11:13 AM
F22's Avatar
F22
That's true for most of the car, but I thought the gas tank was one of the easier things i had to do. It was pretty straight forward!
PS: Nice looking tank! Is it new?
Old Aug 24, 2013 | 12:29 PM
Faster Rat's Avatar
Faster Rat
The tank is not difficult to remove, once you remove all the other stuff. Having a side exhaust car helps.
It gets expensive when you end up breaking the weld on the sending unit aluminum tube and have to buy a new unit.
PS: That is the original '69 tank. It was covered with undercoating and fuel mixed with dirt. Dummy me. Overzealous cleaning with solvents and degreasers, using a scotch pad, removed the protective finish. Had to coat it with clear satin urethane.
Old Aug 24, 2013 | 01:31 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
If you remove the tank sticker will the NCRS boys still consider it stock? After all it's been modified.
Old Aug 24, 2013 | 06:17 PM
Socalrebell
LOL, it's not considered if you remove and replace the same gas tank, but maybe there is where I lost the 2 pts.
Old Aug 24, 2013 | 06:34 PM
F22's Avatar
F22
Geez, mine disintegrated into fragments when I touched it and suddenly a flash of light burst from it and the specks whirred and whirled up and out of the shop.
There was another beer in the fridge, thank God!
Old Aug 27, 2013 | 10:19 AM
tom00799's Avatar
tom00799
I just removed and re-installed the tank on my 70. Removing the filler neck made the tank go in and out much easier. Fairly straight forward.
Old Aug 27, 2013 | 10:48 AM
Easy Mike's Avatar
Easy Mike
...If you remove the tank sticker will the NCRS boys still consider it stock?...
The NCRS does not judge paperwork. That includes tank stickers, invoices, window stickers, car shippers, etc.
Old Aug 27, 2013 | 11:47 AM
TWINRAY's Avatar
TWINRAY
The mice got the better part of mine.
To 69 gas tank removal
