70 model reverse lock out rod
Old Aug 24, 2013 | 10:45 PM
deejaydu's Avatar
deejaydu
Default 70 model reverse lock out rod
Can someone please post a picture of what the "T" handle with the reverse lockout rod should look like. I would like to see the complete rod assembly.
Old Aug 26, 2013 | 10:52 AM
deejaydu's Avatar
deejaydu
Does anyone have a picture of a complete correct "T" handle with rod.
Old Aug 27, 2013 | 09:34 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old Aug 27, 2013 | 01:44 PM
deejaydu's Avatar
deejaydu
Originally Posted by Willcox Corvette
Thank you so much for posting this picture. It looks just like mine but for some reason mine will go into reverse without pulling up on the "T" handle. What is the overall length of that rod? Maybe that is the problem. Mine is approximately 8 3/4". Is there another part that is needed to make it work?
Old Aug 27, 2013 | 07:53 PM
0Willcox Corvette
Former Vendor
I'll have to measure it tomorrow for you for the length. There is a gate screw on the shifter that causes the interference... I'll see if I can get you a pic of that tomorrow as well.
Willcox
Old Aug 27, 2013 | 09:54 PM
deejaydu's Avatar
deejaydu
Willcox
Thank you so much. That gate screw might be my problem.
Jay
Old Aug 28, 2013 | 09:05 AM
Alan 71's Avatar
Alan 71
Hi Jay,
Is the spring at the top of the shifter?
I think that's what forces the rod down into the lock-out, and is the pressure you feel and overcome as you pull up on the tee.
Regards,
Alan
Old Aug 28, 2013 | 10:43 AM
deejaydu's Avatar
deejaydu
Originally Posted by Alan 71
Hi Jay,
Regards,
Alan
Hello Alan,
Yes the spring is in place and it feels just like normal pressure when I lift up on the "T". It feels just like every other 4 speed with a reverse lockout that I have ever had. I guess I will have to take out the console to see what is going on.
Jay
Old Aug 28, 2013 | 11:01 AM
loup68's Avatar
loup68
Army
I had the end of the rod wear down and cause this problem on my 68 4-speed. I bet that that is his problem. Lou.
Old Aug 28, 2013 | 11:38 AM
F22's Avatar
F22
Yep, I really had to study the shifter linkage carefully to see exactly how it works. There's a metal tab at the bottom of the shifter assembly, that when the shifter is in neutral, the rod rests alongside the metal tab and you can't push the shifter over into neutral.
It's only when you lift the finger holds upwards, does that rod clear the metal tab (lifting it up and over) and allow the shifter to move over to the reverse shift actuator.
Old Aug 28, 2013 | 08:29 PM
Lupigiato's Avatar
Lupigiato
Willcox
I was hoping Wilcox would confirm the length and provide a picture in response to the OP, as this may be helpful to me as well. Thanks!
Old Aug 28, 2013 | 09:08 PM
0Willcox Corvette
Former Vendor
Well I didn't remember to measure it.... But you can tell if the rod length is the issue by looking at the shifter.. There is a stop screw on the side of the shifter and when the T handle is down the rod interference with.. When you raise the T handle it clears the screw and you can then move the shifter into the reverse gate path. So if you question the length of the rod or if it is working you can look under the car at the shifter and see.
If the rod is causing interference with this screw then it is the correct length.. if it's not then you have the wrong rod... It's kind of a pain to see this when installed in the car too.
I'll try to post all the measurements tomorrow..
Old Aug 28, 2013 | 09:35 PM
deejaydu's Avatar
deejaydu
Thanks for the great picture and description. I will have to get under my car and see if I can see the screw and where the rod ends. The overall length of the rod would be very helpful in just determining if I need to replace it. Can just the rod be replaced without the "T" assembly.
Jay
Old Aug 28, 2013 | 09:49 PM
Lupigiato's Avatar
Lupigiato
Thanks Willcox!
Old Aug 28, 2013 | 10:10 PM
0Willcox Corvette
Former Vendor
The T-handles are cheap.. In the old days from GM it was serviced separate... but not any more.. 14 bucks for both the handle and the T.
http://willcoxcorvette.com/product_i...oducts_id=4577
Old Aug 28, 2013 | 10:50 PM
Dave J's Avatar
Dave J
The reverse lockout rod shaft on both of my '70 original cars is right at 8 3/4 inches. I could post a picture tomorrow if needed, but there's nothing special at the bottom of the shaft.
Old Aug 29, 2013 | 12:42 AM
deejaydu's Avatar
deejaydu
Hello Dave,
That is also the measurement that I have so my problem must be something else. Maybe the stop screw that Wilcox is showing. I will have to get under the car this weekend and try to figure it out.
Did you get my email about the wipers. I have to figure that out as well.
Jay
To 70 model reverse lock out rod
Old Aug 29, 2013 | 10:30 AM
Dave J's Avatar
Dave J
Hello Jay,
I've taken the liberty of posting a few pics of one of my spare shifters. I believe it is a near NOS takeoff I bought and squirreled away years ago. You can plainly see the stop screw that Mr Willcox was referring to. I also believe this is your problem. Possibly some Bubba mechanic somewhere in the past? The first pic shows the lockout rod in position, and the second is with the rod pulled up. Hope this helps.
I got your message on your wiper problem. Mr Willcox also has a good write-up on this as well.
http://willcoxcorvette.com/repairand...elp.php?hID=95
Good luck my friend..
Old Aug 29, 2013 | 10:44 AM
deejaydu's Avatar
deejaydu
Hello Jay,
Hello Dave,
Thanks for the great pictures. I will investigate it this weekend and should be able to fix it.
Jay
Old Aug 29, 2013 | 07:43 PM
Alan 71's Avatar
Alan 71
Hi Willcox & Dave,
Yes, VERY nice pictures!
Regards,
Alan
