T-Top Trim removal Question
Also. there is a tiny chrome trip on the windshield wiper door and 2 side door pieces. They looked painted on so I'm guessing I'll just have to remove and paint in the color I'm painting the car.
The ss trim on the side of the roof panel is easy to remove by drilling out the rivets and easy to replace. The same thing is true for the small piece of ss trim that 'joins the front and side pieces.
The front piece is harder to deal with since it's 'crimped' into place. Some people remove it and some leave it in place while painting.
The ss trim on the wiper door and top/rear of the fenders was painted, except for the little raised bead at the rear of each trim piece. Taping that bead works.
Regards,
Alan
IF you drill out the rivets you'll need to also drill a small hole in the corner of the under-side of the top panel to get the rivet shanks out.... otherwise rattles!
Wasn't that hard and hopefully it'll go back on okay...although the rubber seal on it was pretty dried out...might think about replacing if they make that part.
