Birdcage!
Old Aug 29, 2013 | 02:15 PM
rayy's Avatar
rayy
Default Birdcage!
I know this has been beaten to death but I am very new to the C3 car so bear with me. I have researched best ways to look for birdcage rust and taking off the kick panel is a good way to spot it. Question one is how does the kick panel come off and second if it has some rust right behind the door hinges is that a death sentence to the cage? Thanks
Old Aug 29, 2013 | 02:36 PM
FatCat's Avatar
FatCat
The kick panel should very carefully pop off. I had to wiggle it forward and down slowly. You could also take a flashlight and look from the outside through the windshield and along the windshield from top to bottom.
Old Aug 29, 2013 | 03:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For the earlier cars, the door sill has to be removed before you can work on getting a kick panel out. The sill traps the front lower corner of the kick panel.
Oxidation behind a kick panel is not necessarily cause for alarm; it comes with age.
Old Aug 29, 2013 | 04:47 PM
ryanmh's Avatar
ryanmh
Once the kickpanel is off, don't forget to pull the speakers out, if present. What you want to see is behind the speakers. If you spot rust flakes in there (fish around a little), further investigation is warranted. Surface rust is expected.
Old Aug 29, 2013 | 06:38 PM
Alan 71's Avatar
Alan 71
Hi rayy,
"is that a death sentence?"
No!
It really depends where and how serious and extensive the rust is, and how expensive to repair the rust will be.
Repairing a rusty birdcage is a serious undertaking because it's so involved to get to the rust because the body panels are riveted and bonded to the birdcage.
My thought is that even at a good purchase price it's something a newer owner should avoid.
Cars with birdcage rust often, (but not always), have a rusty frame, too.
While there are cars out there with all degrees of rust, there are also cars out there with very little or no rust.
Be CAUTIOUS while the money is still in YOUR pocket.
Good Luck!
Regards,
Alan
Old Aug 29, 2013 | 06:52 PM
FatCat's Avatar
FatCat
Oops! Forgot about the Door seal!Good catch..
Old Aug 29, 2013 | 09:36 PM
rayy's Avatar
rayy
Not great pics.
Old Aug 30, 2013 | 08:18 AM
Alan 71's Avatar
Alan 71
Hi r,
The second picture tells more than the first.
In the first picture MOST of the parts you're seeing are fiberglass and the rust appears to be stains from the rusty windshield post shown in the second picture.
From what I can see of the structure/barn this car is stored in the rust doesn't surprise me. Finding a special car that needs serious work in a barn is exciting, finding an ordinary car that needs serious work in a barn isn't so good.
From these two pictures I'd say this is a car that needs to be checked out very carefully.
Again... just from the two pictures... be careful!
What are you looking for in a car?
Regards,
Alan
Old Aug 30, 2013 | 09:16 AM
rayy's Avatar
rayy
I am wanting a budget auto X car that I can drop a 6.2 Ls in and have some fun. That being said I don't want to purchase a car that is rusted down even if it is cheap. I have known the car for years and it just recently came up for sale due to a death. The car is priced in the 3500 range. The mounts look good as does the frame. The pic beside the vin tag is what scared me it looked to be rusted good but when I pressed on it with a screwdriver it was solid. The owner is very nice and said I could take the kick panel off and whatever else I wanted to.
Old Aug 30, 2013 | 09:27 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
What else is in the barn and available?
WB
Old Aug 30, 2013 | 11:43 AM
rayy's Avatar
rayy
Not sure. A Ton of moper stuff.
Old Aug 30, 2013 | 04:14 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
well one idea is a combination of welding and body panel adhesive, I had posted a bunch about this, search my name, don't want to repost it all here....in sensitive areas, I would opt for body panel adhesive....adhesives will hold longer then welds most times when pulled on a frame machine
Old Aug 30, 2013 | 05:34 PM
rayy's Avatar
rayy
So remove the kick panels and what else? The guy said I could take off anything I wanted. And the panels just pop off right? They appear to be under the seal plate which from what I see does not have any screws. Thanks
Old Aug 30, 2013 | 10:56 PM
my 76 ray's Avatar
my 76 ray
You don't say what year it is but I have a '74 and a '76 and they both have four screws running down the middle of the sill plate.
Old Aug 31, 2013 | 12:14 PM
rayy's Avatar
rayy
A few more I got today.
Old Aug 31, 2013 | 08:47 PM
gcusmano74's Avatar
gcusmano74
Hard to say from here. What I can see doesn't look so bad.
Poke at it with a screwdriver to tell if it is soft or not. Everywhere.
Old Aug 31, 2013 | 09:25 PM
rayy's Avatar
rayy
I did it feels real solid. But a lot of rust flakes behind the kick panel. I guess for the money I can't say much. But from what I have read if its is rusted it's money wasted.
Old Aug 31, 2013 | 10:35 PM
LT-1 kid's Avatar
LT-1 kid
from your pics, it looks ok, seen worse, seen better.
Old Sep 1, 2013 | 12:13 PM
Roco71's Avatar
Roco71
Try to look down into the lower corners of the frame where the fenders and surround meet. The upper part of the frame is far easier to repair than the bottom half.
To Birdcage!
