1982 surging problem
Old Aug 30, 2013 | 05:07 PM
2001convertable's Avatar
2001convertable
Default 1982 surging problem
Hi, I had the car running excellent then all of sudden the next time I went to use it , it was surging. As soon as I start the car the engine surges.Someone thought it could be the timing so I tried to set it disconnecting the tan and black wire.I had to reconnect and not time the car as I couldnt get the car to run smooth in order to set it. Any suggestions?
Old Aug 30, 2013 | 05:28 PM
Arkyvette's Avatar
Arkyvette
Did your battery go dead between driving it fine and surging? If so your idle air controls need time to reset above 30 mph for a few miles. If not, they might be dirty/stuck
Old Aug 30, 2013 | 05:35 PM
2001convertable
Hi, thanks for getting back to me. No, my battery has not died. I have driven it more than 30 miles. This is driving me nuts..
Old Aug 30, 2013 | 05:37 PM
2001convertable
I did change one iac. Someone told me it can be a vacuum leak but I cant see it as I have 20,000 miles on the car and as far as it can see the vacuum lines look great.
Old Aug 30, 2013 | 05:51 PM
Arkyvette's Avatar
Arkyvette
Easy to check for vac leak. Plug the connections at the manifold and throttle bodies, except for the map sensor. Then test and see how it runs. Other considerations are fuel pressure from clogged filter or possible failing pump. Letting ethanol gas sit around in the tank can't be good for these. I recommend reading the 82 sticky post in the tech forum for great ideas about this.
Old Aug 30, 2013 | 06:01 PM
2001convertable
I changed the fuel filter twice in the last 2 month thinking it can be clogged. I also emptied the tank and replaced with fresh gas.
Old Aug 30, 2013 | 06:10 PM
2001convertable
thanks, I never knew that info was available. It has alot of info. I will read it asap. thanks Anthony
Old Aug 30, 2013 | 11:36 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
what was the difference in time between it running excellent and then surging? as Arkyvette suggested, read the "sticky" in the above section.....(thanks Arkyvette)
you need to check all connections, plug wires, electrical wires, vacuum hoses, etc.
did you do anything to the motor during the time it ran great and the surge? what was the reason for you changing the one IAC, and was it done in that time interval?
even though you only have 20,000 miles on the Vette, doesn't mean that the vacuum hoses are all good. one area to check is under the left top front fender (driver's side) where a vacuum hose goes into the cruise control transducer, as that is hidden from sight, and may have a nice size split in it as it curves, you never know, I know my 82 did....
you'll get it running excellent again, it may be something very simple...
Old Aug 31, 2013 | 12:21 AM
2001convertable
I changed the iac because I broke it screwing it in to tight and It snapped at the base.The car was not running good when I bought it and I had a check engine light .The engine ran rough .I changed the ecm and the car came alive and check engine cleared. It ran fastastic. Then two weeks later the car started acting horrible.No check engine light or running rough but now the car seems as if its surging or searching.Hard starting when hot.I cant even time the car.Thought it maybe timing.
Old Aug 31, 2013 | 12:37 AM
74 LS4-454's Avatar
74 LS4-454
mmmmmmm.......
1-at what speed does the engine surge or search?
1a-is this only at idle?
1b-can you drive the Vette under these conditions?
1c-does it smooth out at higher speeds?
2-does the engine start when hot (about how many seconds before it starts hot?)
2a-or do you have to wait for a few minutes for a restart?
3-is and have you rechecked to see if the PROM chip is seated correctly after replacing the ECM?
4-have you checked the vacuum lines again???
Old Aug 31, 2013 | 10:00 AM
Arkyvette's Avatar
Arkyvette
And...what is your fuel pressure?
Old Aug 31, 2013 | 02:17 PM
2001convertable
I have to check the fuel pressure. I never did it before.
Old Jul 8, 2014 | 09:48 PM
2001convertable
I changed the fuel pump with the 1982-84 not the 85 which I was told is better. I had ordering it already. Well after changing the pump the surging stopped and car ran great. That was the surging problem go figure. thanks to all that helped. PS. the pump was so easy to do.
To 1982 surging problem
