Power vs Standard Brakes
Old Sep 6, 2013 | 09:55 PM
gr8t73's Avatar
gr8t73
Default Power vs Standard Brakes
Took my 73 out for the first time and have a question regarding the brakes. The 73 has standard brakes & it seemed to take an excessive amount of foot pressure to operate the brakes. I am not sure if this is a problem or normal as this is my first C3 with standard brakes. I previously had a 77 but it was a power brake car so I have no point of reference. I realize the standard brakes are going to take more effort just not sure what's normal. Any comments
Old Sep 6, 2013 | 10:28 PM
540 vette's Avatar
540 vette
If the master was replaced with one from a power brake car it will need more foot pressure. If it is a master from a manual brake car it should feel normal.
Old Sep 6, 2013 | 10:39 PM
MakoJoe's Avatar
MakoJoe
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
If you want to take the time and expense a conversion kit is available. While most of my classic cars had power assisted brake systems I had one that was not. A 1971 Ford F100 that I bought that previous owner installed a 390 out of a 1967 Ford Fairlane 500. While I enjoyed the off the line power in a light pickup truck stopping it totally sucked. I used to haul stuff like a lot of fire wood It did have disks in the front. But had to stand on the brakes to stop it.
While I do agree with the other dude that someone might have installed the wrong master in it not very likely they have different part numbers and that would have been a huge mistake on the previous owners part.
Old Sep 6, 2013 | 10:47 PM
ebertthebull's Avatar
ebertthebull
I like non power brakes I think they have more feel.It was a pita to change over my 75. A bonus is you always have the same brakes regardless of your vacuume level. Especially if you have a lumpy cam with low vacuume. I f you need it to stop / slow in a hurry it will be no problem.
Old Sep 6, 2013 | 10:54 PM
Duane4238's Avatar
Duane4238
If your non-power brake system is working correctly, it should stop you with no problem and very little brake pedal pressure. I have non-power in my '72 and it stops as well as my '05 Civic with power brakes and actually stops twice as good as my '98 Silverado with power brakes. It sounds like you might have something wrong with your system.
Duane
Old Sep 6, 2013 | 11:06 PM
MakoJoe's Avatar
MakoJoe
Try bleeding out your system with a good quality DOT3/DOT4 synthetic brake fluid. Buy about 2 quarts to bleed it fully. It will probably only need one quart but get 2 to be safe.
Start on the passenger rear, than drivers side rear, passenger front and then drivers side front. Old fluid can also cause problems in the braking on the car.
Old Sep 7, 2013 | 04:41 PM
gr8t73's Avatar
gr8t73
I drove around a bit more & am convinced the amount of foot pressure required is a bit excessive. If the brakes need bleeding could this cause the high pedal pressure. I always thought that air in the system would cause a soft pedal. Any help would be greatly appreciated.
Old Sep 7, 2013 | 05:15 PM
ddawson's Avatar
ddawson
Good to great pads make a huge difference as well.
Yes air usually gives you a soft mush pedal. If it's firm all the through the travel I'd be looking at something else. Of course it's always wise to bleed them if you have not done it in two years.
It could also be a hung caliper. On mine one rotor looks pretty crusty because the pistons were not pushing the pad against the rotor very well. So I replaced both sides with new ones.
Old Sep 7, 2013 | 07:09 PM
gr8t73's Avatar
gr8t73
Thanks D I will bleed the brakes for good measure & check all the calipers while I am at it.
Old Sep 7, 2013 | 09:02 PM
gcusmano74's Avatar
gcusmano74
My '74 has no power brakes and I only notice the difference in a "panic" stop.
The power brake master cylinder doesn't look any different from the outside, but the bore is 1/8" larger. This shortens the pedal travel during a brake application.
Old Sep 7, 2013 | 10:15 PM
7T1vette's Avatar
7T1vette
The braking system should work equally well, whether manual or power, if the system is configured correctly. The only difference will be "pedal effort". But, you can do a full panic stop with both systems and have about the same stopping distance.
If your braking performance is not up to par, it's NOT because you have a 'manual' braking system.
Old Sep 7, 2013 | 10:25 PM
gr8t73's Avatar
gr8t73
7T1Vette, my brakes work fine other than the high pedal effort. I can lock the tires up & the car stops in a straight line. I am certain the pedal effort should not be so high but am at a loss as to what the problem might be.
Old Sep 8, 2013 | 03:00 AM
MakoJoe's Avatar
MakoJoe
Well you're just not used to a non power system Convert if you do not like it. Link I sent you is inexpensive and what like $300 bucks.
Non power brakes suck and are stand on the pedal. I have owned them in the past. 4000 pounds of car is hard to stop and power assist will decrease the stopping Distance by a lot. Buy a upgrade or get used to it. Hell I have owned cars with four wheel Drum Brakes and you want to know what it is like to stop one of these cars without power brakes. HMM better not have someone lock up brakes in front of you at least your Vette has 4 Wheel Disk Brakes
If you have ever driven a power brake car then lost the engine power then you will really know what non power brakes feel like. Was driving my 1972 El Camino down a Highway at about 70 MPH and the rotor in the distributor cap failed and blew apart. Engine stalled at 70 MPH and I had no vacuum assist on the brakes. Can tell you it sucked and was much harder to stop than anything I had without power assist
Old Sep 8, 2013 | 11:11 AM
David Mc's Avatar
David Mc
Power assist was rare on vehicles with drum brakes. Drum brakes were "self energizing" .When disc brakes were install power assist became (almost) mandatory because the higher pedal effort needed.
My '67 has no power brakes. My '72 does. While both cars stop fine the '67 requires significantly more muscle from my leg.
Old Sep 8, 2013 | 11:31 AM
gr8t73's Avatar
gr8t73
If in fact the brakes are working properly & the pedal pressure is normal for standard brakes I will have to convert to power brakes as I don't feel the car is safe as it is.
Old Sep 8, 2013 | 12:22 PM
7T1vette's Avatar
7T1vette
As mentioned earlier, the manual brake master cylinder has a larger piston diameter than the power brake M/C. If someone installed the wrong M/C, it will require even higher pedal effort.
Old Sep 8, 2013 | 02:49 PM
mrvette's Avatar
mrvette
THIS/\ is true, so check the diameter of the cyl.....
IF you have the correct m/cyl.....I recommend you do a hydroboost install, instead of the silly vacuum system....it runs off your power steering pump, but since manual brakes, maybe it's manual steering also, in which case....well....I would see two upgrades....
To Power vs Standard Brakes
Old Sep 8, 2013 | 05:47 PM
gr8t73's Avatar
gr8t73
My 77 had the factory power brake system & I was happy with the braking on it. I hear a lot of good things about the hydroboost system but I prefer the stock look myself. I am certain someone on the forum has made the conversion from non-power brakes to the factory power brake system & can walk me through the process.
Old Sep 8, 2013 | 05:58 PM
Griff2002's Avatar
Griff2002
My 72 with manual brakes requires a lot of pedal effort but stops well. I had a 72 Nova many years ago with manual brakes - those brakes required quite a bit of effort too. I thought the whole purpose of power brakes was to reduce the pedal effort?
Thanks for the tip on the master cylinder. I'll have to check that out. I guess there should be a part number on it that I can check.
Old Sep 8, 2013 | 07:27 PM
loup68's Avatar
loup68
Army
Manual brake master cylinders bore are 1" and the power brake master cylinders are 1 1/8". Lou.
