How to remove spindle flange
Old Sep 7, 2013 | 10:55 PM
mcltcb's Avatar
mcltcb
Default How to remove spindle flange
I need to replace a rear spindle flange on my 75. Can I just remove that big nut and use a claw type puller?
Old Sep 8, 2013 | 01:24 PM
TimAT's Avatar
TimAT
Remove the cotter pin and nut, I think I'd be in favor of using a balancer puller- bolt it on to the flange and pull. Way less chance of it slipping off. Even better would be to use a bearing puller- the 2 big plates that have some HD bolts down each side, then bolt the puller to that.
Old Sep 8, 2013 | 02:59 PM
tracdogg2's Avatar
tracdogg2
Just remove the nut and pull with your hand. It is not a press fit.
Mike
Old Sep 8, 2013 | 04:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Mike
If it is stuck, tap on it and it should slide right off.
Old Sep 8, 2013 | 04:20 PM
TimAT's Avatar
TimAT
Mine must have been special. I tried tapping, then beating, then the puller. Then they came off. Just stuck I guess.
Old Sep 8, 2013 | 07:13 PM
929nitro's Avatar
929nitro
Mike
Just rebuilt both sides on my 75. Removed cotter pin and nut and slid them off.
Old Sep 10, 2013 | 10:13 PM
mcltcb's Avatar
mcltcb
Thanks everyone for the replies. It did in fact come right off after removing cotter pin and nut.is that nut a one time use? Thanks again everyone.
Old Sep 11, 2013 | 09:19 AM
929nitro's Avatar
929nitro
If you are replacing your wheel bearings the kit I bought included a new nut and cotter pin with the bearings, race and seals.
To How to remove spindle flange
