Doorgunner's '68 Convertible Project
Old Mar 24, 2023 | 12:03 AM
  #6721
OldCarBum's Avatar
OldCarBum
That hood release looks awesome
Old Mar 24, 2023 | 09:46 AM
  #6722
doorgunner's Avatar
doorgunner
2026 Loser of the Year
It was really nasty/scratched up with original black paint and cruddy white lettering. It took about an hour to sand and polish the potmetal/fill in the lettering/clearcoat with fast-drying model car paint.
Let's look at it again .......
I keep getting side-tracked easily, but I'll seriously try to finish the dash reinstall today.
Old Mar 24, 2023 | 05:05 PM
  #6723
doorgunner's Avatar
doorgunner
Did not happen(ed).....but I made progress. I installed the vacuum hoses/the overide switch and routed the hoses through the firewall this morning/then chased parts/screws/etc.....
This afternoon I set the driver's panel in place/NO problem...EXCEPT....the lower part of the panel warped from hanging on the pegboard for a year ...my fault! I will fabricate a brace to make the lower part of the panel straight agai where thesteering column sticks through......
I COULD have mounted the center gauge cluster, but it would probably be in the way while installing the brace under the driver-panel.
I did find a 2nd wire from the alrm module that should hve been connected to a relay rather than the siren...easy fix.
Now I can wrap all those exposed wires I see behind the gauge cluster ........
Will be back tomorrow with more pics...unless God has different plans.
Old Mar 25, 2023 | 09:59 AM
  #6724
doorgunner's Avatar
doorgunner
Now that I have the driver panel neatly in place.....
I THINK I'LL REMOVE IT
It's "Buck-Toothed" really bad at the very bottom where the steering column fits...and looks even worse this morning.
It will be much easier to fab a stout horizontal brace on the workbench.
Thanks again you guys for convincing me to add the extra foot of wiring to all the dash gauges.
The panel install is now a 3 minute job!
Now...out to the garage to do some blacksmithing
Old Mar 25, 2023 | 10:56 PM
  #6725
doorgunner's Avatar
doorgunner
Here we go Bubba...a badly bowed panel...the trim piece that covers the steering column won't fit...
Pulling one side down of the support and drilling holes for screws......
Fabricating dog-leg braces and cutting bolts to length......
Drilling/tapping/installing 2 braces.....
Much flatter.....
The trim piece actually fits now...the dog-leg brackets will hold the bottom of the trim piece securely.......
Now to reinstall the gauge panel and fab 2 rods/braces to connect the steering column support to the horizontal panel support.
Old Mar 26, 2023 | 12:07 PM
  #6726
loup68's Avatar
loup68
Army
Tony, how are you going to install your under column manual controls with the brace there? Lou.
Old Mar 26, 2023 | 12:38 PM
  #6727
doorgunner's Avatar
doorgunner
GOTCHA! I'm counting on U forum members to figure that one out. I need to pull up a pic on the web to see the original locations...in three years "I forgot"
When I finish bolting the braces in place I'll post some pics of the possible switch/odo reset mounting points from different angles.
Remember...since it's a basketcase, "close-enough" and functional is what counts.
Old Mar 26, 2023 | 02:34 PM
  #6728
loup68's Avatar
loup68
Army
Just curious, where were your controls located? Very early 68's had the round **** and then the two pull down controls under the tach on the right side. . Then they put them centered under the steering column, one vacuum control on each side of the round ****. Lou.
Old Mar 26, 2023 | 05:28 PM
  #6729
doorgunner's Avatar
doorgunner
Sorry I didn't explain everything....the odo reset and the vacuum over-ride were just hanging under the dash. It doesn't matter to me where they get attached, but I don't have a bracket to mount then directly under the steering column,,,so that location is out.
I found this pic from ALAN71.....
I'll go to the garage and take pics of the brackets I found...will be back in 10 minutes.
Old Mar 26, 2023 | 05:38 PM
  #6730
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
They are wat outside your bracket on my 68. You should be fine
Old Mar 26, 2023 | 06:50 PM
  #6731
doorgunner's Avatar
doorgunner
Here we go...I found everything that came with the car as far as vacuum switch and odo. reset....
I shortened the left odo bracket so it would bolt next to the vacuum switches.....
I installed the odo reset cable....no twists or sharp bends in it........
It's not original, but it may work
4) #8 srcews hold the horizontal bar/support in place...I will unscrew it to reinstall the steering column.
NOTE to myself: While the center cluster is out...run a fused hot wire from battery to clock* and to radio*
Old Mar 27, 2023 | 12:12 PM
  #6732
OldCarBum's Avatar
OldCarBum
Looks good!
Old Mar 27, 2023 | 05:00 PM
  #6733
doorgunner's Avatar
doorgunner
Thanks O.C.B. Between running the roads/V.A. appoint./etc...I did a little cleaning up the gauge wiring/it was really nasty....
Hopefully I can reinstall the driver-side gauge panel today.
Old Mar 28, 2023 | 12:06 AM
  #6734
doorgunner's Avatar
doorgunner
The gauge wires are organized (somewhat).....
I found an original firewall thru-hole to the left side of the steering column directly behind the speedometer (no more fighting bends and the steering column to connect the speedometer cable--it's a straight shot the gauge.....
Red backlighting (it's that aviation thing going on)......
Same deal on the center cluster.......
NOTE TO ME: CONNECT THE OIL LINE BEFORE REINSTALLING THE CENTER GAUGES!
Old Mar 28, 2023 | 12:02 PM
  #6735
OldCarBum's Avatar
OldCarBum
The red looks cool.
Old Mar 28, 2023 | 12:16 PM
  #6736
doorgunner's Avatar
doorgunner
Thanks O.C.B. ...the camera makes it have a slightly pink tint.
Now..back to the garage to finish the dash insulation
Old Mar 28, 2023 | 12:59 PM
  #6737
OldCarBum's Avatar
OldCarBum
Don’t forget to connect the oil line before the center gauges console
To Doorgunner's '68 Convertible Project
Old Mar 28, 2023 | 01:32 PM
  #6738
doorgunner's Avatar
doorgunner
YOU know me well....DON'TCHA !
Old Mar 28, 2023 | 01:58 PM
  #6739
OldCarBum's Avatar
OldCarBum
I’m just trying to help a friend out.
Old Mar 28, 2023 | 06:30 PM
  #6740
doorgunner's Avatar
doorgunner
You guys are right...(parts somehow jump from one box to another)...AGAIN !
I started to install the center cluster...but first CONNECT THE OIL GAUGE LINE.
THEN I noticed...NO Wiper Switch...NO problem...looked on the pegboard...
NO switch.
Digged thru 10 labeled boxes... NO. Switch.
Don't you love it when the gremlins steal stuff.
