Doorgunner's '68 Convertible Project
Old Dec 13, 2014 | 06:46 AM
  #801
SB64's Avatar
SB64
Originally Posted by doorgunner
The good news is...........I slept.
The bad news is..........it lasted only three (3) hours!
Should I gulp some coffee and go into the garage to button up the rear suspension..............or............
I KNOW!
RVZIO will be waking up in another 30 minutes in Virginia....
He'll know what to do!
(In the meantime.....I'm going to the garage )
That's right DG, how'd you know. Now I'am in big trouble. When I can't sleep I will turn on the garage heat and go to work. Not sure if the neighbors will appreciate it but hey I don't give a d---.
By the way you are doing a nice job on the rear suspension. Glad that oil pan job is off the list. More coffee please. Now carry on!
R
Old Dec 13, 2014 | 12:22 PM
  #802
doorgunner's Avatar
doorgunner
2026 Loser of the Year
R
It's so nice to be able to walk in the garage without slipping down from oil puddles!
Now.....about that rear suspension.....I just finished reassembling everything.
The spring leaf mod works great.........TOO GREAT!
The tire-to-fender-lip gap went from 2 inches to 3&3/4 inches....ooops!
That notched leaf above the new main leaf REALLY supports everything!
I'll drive the car after while to get the spring-pack to settle...it will probably settle a little more over the next week also.
Annnnnnnd another thing.....having never driven a Vette before, I noticed how the rear of the car squatted down a lot when accelerating hard....probably 5-6 inches....and the nose came UP equally. (Not the case on my '69 Camaro----the rear squatted about an inch/the nose came up about 5 inches.
Anyhow........I'm interested in seeing if the leaf mod helps that problem out.
44000
Old Dec 13, 2014 | 11:53 PM
  #803
doorgunner's Avatar
doorgunner
The modified spring-pack works great.....no more bottoming out.....
no body-roll in corners.....no squatting on take-off..........
the rear end drops about an inch on hard acceleration and the nose raises about 4 inches.....perfect.
Old Dec 14, 2014 | 06:05 AM
  #804
SB64's Avatar
SB64
As you would say DG AAAAAAAAAAAAANNNNNNNNNDDDDDDD that's a rap! Onto the next issue, what is the next issue??????
R
Old Dec 14, 2014 | 08:03 AM
  #805
doorgunner's Avatar
doorgunner
R
ADD. PTSD...POLITICIANS...Freezing-Laptop....dragging starter.....
Alex............Dragging starter for $500!
EDIT: BUT FIRST........the exhaust pipes are black/carb is too rich at idle and cruise/edelbrock carbwith metering rods has .100" primary jets (Holley carb in '34 street truck has .068 primary jets but no metering rods).
Maybe I can get away with .090" or .095" primary jets!
I'll get a pair tomorrow and install them.
Old Dec 15, 2014 | 07:25 PM
  #806
doorgunner's Avatar
doorgunner
Good news...........I installed a pair of .080" primary jets in the edelbrock carb...
The engine started great but would run only about 5 seconds.....
Then......I installed a pair of .085" jests.....the engine started and idled great but bogged under moderate acceleration.
THEN.....I installed .090" jets......and the engine does everything it's supposed to do!
The exhaust sound is a bit crisper also...
test drive tomorrow since it rained most of the day......
Annnnd maybe troubleshoot that starter!
Old Dec 15, 2014 | 07:41 PM
  #807
Jack605's Avatar
Jack605
Don't worry DoorGunner the starter is not going anywhere.
Old Dec 15, 2014 | 09:12 PM
  #808
doorgunner's Avatar
doorgunner
Whew!!!! I will be able to sleep now!
Old Dec 16, 2014 | 11:43 AM
  #809
doorgunner's Avatar
doorgunner
It runs like a champ now.......no more blubbering exhaust note when accelerating or decelerating......starts quickly! I'll check the starter when I get finished having fun.
Old Dec 16, 2014 | 12:50 PM
  #810
Brack c's Avatar
Brack c
Gotta love Our 75° December weather huh DG ?? LoL
Old Dec 16, 2014 | 01:21 PM
  #811
Jack605's Avatar
Jack605
We have been excited to be in the 40's for the last week, the ponds are no longer frozen.
Old Dec 16, 2014 | 01:26 PM
  #812
doorgunner's Avatar
doorgunner
I haven't had the top on yet..........
Old Dec 16, 2014 | 05:20 PM
  #813
briankeery's Avatar
briankeery
Old Dec 16, 2014 | 10:46 PM
  #814
doorgunner's Avatar
doorgunner
Originally Posted by briankeery
OOOOOOOOOOOOOOOOOOOOOPS................. ...................
Old Dec 18, 2014 | 12:08 AM
  #815
doorgunner's Avatar
doorgunner
yes...they (Harley chrome glass pack mufflers) look nasty mounted under the differential.....and the reverberation will rattle your teeth because there is no tire tub to prevent the sound from going up into the cargo area!
I have decided to extend the exhaust pipes so that the mufflers will exit at the rear of the bumper.....hopefully I can post pics and sound tomorrow night.
Old Dec 20, 2014 | 07:19 PM
  #816
doorgunner's Avatar
doorgunner
The exhaust mod was side-tracked......now it's back on schedule.....(pardon the A.D.D. mess!)
I'm mocking up some DIY exhaust pipe "parts 'n pieces" for phase 2 of the exhaust experiment......this.........
has now turned into this.........(as much as I dislike exhaust wrap---I dislike a hot floorboard twice as much)..................
While I was correcting exhaust problems, I found THIS..............
It was fried so badly that the inner drive cable could be seen turning when the male end was rotated by hand!
I going back to the garage to finish installing the "new trial exhausts"...will be back in an hour or so.
Old Dec 20, 2014 | 07:35 PM
  #817
chazde3's Avatar
chazde3
Hey doorgunner, I may have missed it through the thread, are you going back to chrome bumpers or keeping the rubber bumpers?
To Doorgunner's '68 Convertible Project
Old Dec 20, 2014 | 08:56 PM
  #818
doorgunner's Avatar
doorgunner
First......before the answer-----A PICTURE ........
the shiny thing on the bottom end of the exhaust is the Harley Davidson muffler (one of a pair)....
Now for the answer.....Bubba "upgraded" the front and rear fiberglass to '76 style bumpers/tailightpanel/exhaust panel........
I intend to "regress" back to the '68 front and rear fiberglass......
In the meantime, I'm experimenting with the exhaust system and sound.
I'm going back to the garage in a few to install the passenger-side exhaust shown in the above pic.
EDIT: I'm still thinking of changing the title of my thread to "The opposite of RVZIO's thread!"....LOL
Old Dec 20, 2014 | 09:30 PM
  #819
chazde3's Avatar
chazde3
Oh thank god. Too bad you aren't closer, pretty sure I have some rear clips you would find useful. Probably some front end pieces as well.
  #820
Brack c's Avatar
Brack c
edit: I'm still thinking of changing the title of my thread to "the opposite of rvzio's thread!"....lol
lol , great call DG
