Doorgunner's '68 Convertible Project
Old Feb 15, 2026 | 11:35 PM
  #8461
doorgunner's Avatar
doorgunner
2026 Loser of the Year
God will.
He must like classics because he lets us stay around.
Excellent point...I know he likes the classic wording of the KJV...He said so.
Old Feb 16, 2026 | 07:51 AM
  #8462
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I ran into the off center engine while i was trying to get the dumps mounted to the side pipes...the passenger side is a bear
Old Feb 16, 2026 | 12:59 PM
  #8463
doorgunner's Avatar
doorgunner
Would you be better off using a center line run all the back from the tail section up to the nose?
Just throwing a monkey wrench into the works.
R.R, I completely forgot about the offset.
OCB.....GOOD CALL...I took pics of my Southern Engine-eering Centerline set-up. Using the length of the car to get the nose centerline....my 1st attempt ar making a centerline ended up being 3/8" off compared to the string running from the firewall.
You can't see the centerline on the rear spoiler, but one is there also.
I have a 2nd centerline near the gas fill lid area..
A 3rd centerline on the hardtop near the windshield.
A 4th centerline on the DIY fan shroud.
A 5th centerline on the center of the hood surround.
THE STRING ISN'T TOUCHING THE HARDTOP/CAMERA OPTICAL ILLUSION.
All the centerlines above were right on when I used a plumb bob…except for the nose centerline.
NOW...to recenter the radiator support and rebolt the fender supports to it.
Old Feb 17, 2026 | 08:39 PM
  #8464
doorgunner's Avatar
doorgunner
Allow me to RAT myself out again...The passenfer fender bolted on easily BUT it had 4" of clearance between the tire tread and the wheel well arch! AFTER 30 minutes of puzzling I found that I had made the DIY radiator support rectangular is shape rather than smaller at the bottom.
So out came the support...cut 3" oof the bottom width and welded it back together. T radiator slid into it.
CURSES ON THE BRAIN TRAUMA AND PTSD!
I'M BACK IN BUSINESS AGAIN. IT'S UGLY BUT STOUT.
Old Feb 17, 2026 | 10:51 PM
  #8465
Giddy-up Go's Avatar
Giddy-up Go
Glad to see you aren’t blaming any of it on 3/4 of a century!! Goad you brought this up because I never even thought about it!
Old Feb 18, 2026 | 01:22 PM
  #8466
doorgunner's Avatar
doorgunner
yOU GUYS TOLD me about the shape of the support about a year ago...something I should have copied and put in my Forum Repair Folder. I knew better than to make a perfect rectangle, but combat memories and my son's murder by an Illegal Aliem are ALWAYS taking up 99% of my time.
I'm going to the garage now to center the radiator support and bolt it to the crossmember.
Tnen I will lift the fender into place and test fit it.
Old Feb 19, 2026 | 12:20 AM
  #8467
doorgunner's Avatar
doorgunner
I recentered the bottom of the radiator support which was 1" oof the the left after cutting the lower left and right legs to get the correct shape.
The fender support is now firmly mounted to the side of the radiator support.
THIS TIME THE REPAIR IS "FOR REAL"...ALL PROBLEMS ARE NOW CORRECTED.
The height of the fender arch dropped down to where it was before this trvesty started!!
The tire is now centered in the wheel well and after tighteneing all mounting bolts--it stayed centered !!!
This took 8 hrs. to do it right and repair my mistakes, but the fender is in the correct location.
Next... to fit the end of the rear edge of the fender to the contour of the door which will take more fiberglass work to close the door/fender gap.
Old Feb 19, 2026 | 01:06 AM
  #8468
Giddy-up Go
Excellent! Glad you have no more problems! 😂 And that it only took 8 hours! If I could fix all my problems in 8 hours it would be a jubilee! Alright! Let’s ride Tony! 😊
Old Feb 19, 2026 | 10:36 AM
  #8469
doorgunner's Avatar
doorgunner
Yep Andy...now all I have to do is repair & fit the driver fender!. Hopefully it will only take 8 hours!!!
Old Feb 19, 2026 | 07:28 PM
  #8470
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
I really hope that Andy is right and that you have no more problems! Keep at it, we can't wait to see the finished product.
Old Feb 20, 2026 | 08:27 PM
  #8471
doorgunner's Avatar
doorgunner
Thanbks N...Me hopes so too. I ruined errrr....ran the roads today for precious so I monly had time to make notes on masking tape for the passenger fender...turns it needs more work/replace the trough and contour the fiberglass where it meets the door.
TRY again tomorrow!
Old Feb 25, 2026 | 08:13 PM
  #8472
doorgunner's Avatar
doorgunner
V.A. medical tests all day...now I can get some garage time tomorrow!
Old Feb 26, 2026 | 04:49 AM
  #8473
Rescue Rogers
Good luck Tony!!!!
Old Feb 26, 2026 | 11:12 PM
  #8474
doorgunner's Avatar
doorgunner
Everything is O.K....BACK to the car!
Thanks R.R.!
Old Feb 26, 2026 | 11:15 PM
  #8475
stingrayiii67's Avatar
stingrayiii67
One of the most fascinating threads here. Keep up the good work. I enjoy coming here and seeing your progress.
Old Feb 26, 2026 | 11:29 PM
  #8476
doorgunner's Avatar
doorgunner
Thanks stingray...you and I seem to be dealing with similar battles!
Old Feb 26, 2026 | 11:33 PM
  #8477
Giddy-up Go
DT got thru her purging and testing today and likewise got a great report. So prayerfully may get to the garage tomorrow-temp of my age!! Of course more cold and snow coming Sunday
To Doorgunner's '68 Convertible Project
Old Feb 26, 2026 | 11:43 PM
  #8478
doorgunner's Avatar
doorgunner
I'm glad you got a YES on that prayer for her! That lightens the burdens a lot.
Old Feb 27, 2026 | 12:00 AM
  #8479
stingrayiii67
Yep that is for sure. And we have almost the same looking car, a black convertible. lol.
Old Feb 28, 2026 | 10:39 PM
  #8480
doorgunner's Avatar
doorgunner
Fix the lawnmower mow grass...look at Vette.....fix the weedeater/kinda' weed eat....look at Vette....maybe tomorrowwww.
936500
