Doorgunner's '68 Convertible Project
Old Oct 19, 2013 | 06:29 AM
  #81
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by 1974ta
Took me three weekends to finally get my dash harness back in so you have something to look forward too
Exactly....I spent a month putting a '93/'89 harness in the '34 pickup.
Since you are back there have you replaced all light bulbs? I also highly recommend going through all the gauges.Will do....bulbs are waiting for me at Grainger/gauge panels will remain loose & not be reinstalled until all lighting & gauge-wiring is tested.
Getting the center console and harness in correctly was harder than removing the trailing arms. Toughest job on a vette IMHO other than maybe removing the PB booster.
It is all worth in in the end. Ain't it the truth on both counts!
Bill
Originally Posted by FatCat
Yes sir!! I have been watching the whole time!! I had a frustrating couple of weeks with mine though an slowed down my posting on others... Haha
Hang in there, F.C----I sold my first showroom purchased car/'69 Camaro convertible---because I got tired of working on it after 15 years-------BAAAAAD mistake.........Also----There's a few times that I wanted to put a $250 For Sale sign on the truck when sitting on the side of the highway until I got the wiring bugs out
Originally Posted by RBrid
Nice work Doorgunner. Good luck with the dash harness. You have an original emergency brake handle mounting there in post #69
I TOLD you guys to keep an eye on me...those V.A. meds/PTSD/ADD have me going "Why did I do THAT!" sometimes!
Well.............................out to the GO-rajj.
Old Oct 23, 2013 | 06:00 AM
  #82
doorgunner's Avatar
doorgunner
MAN!
If you don't do any work on your car for a few days.....You drop to page #6 on this Forum!
I HAVE to quit dodging that dash wiring.......a little progress/not much---along with daily life-interruptions...
The gauge bulbs have been replaced/gauges have been tested and new cables have been installed on the heater-box/vent doors....
The A.D.D. took over.....I HAD to give the headlight covers a light sanding/clearcoat of .....Krylon..... .....to see if the old paint could be salvaged while the car gets roadworthy/bugs get worked out.....YES! A "10 foot" touch-up job is in order!
I should re-title this thread......."The Poor Man's Guide to Resto-Modding!"
Old Oct 25, 2013 | 09:10 PM
  #83
doorgunner's Avatar
doorgunner
Finally my brain focused enough to get some dash wiring installed.....
annnd.....everything actually works...(I still need the headlight switch retaining nut/ignition switch retaing nut)
Man! That left visor has some dusty handprints all over it.....
Tomorrow........the console........maybe.....God willing!
Ohhhhh......I accidentally started the engine while working the key switch to check the gauges and signal lights.....(any other time it would have taken 30 seconds to start it from "sitting-up" for years!
It was a LARGE relief to realize that I had connected the oil pressure line to the oil gauge. I had to fumble with the key a few seconds before it went to the OFF position because there is no retaining nut holding it in place YET--aarrrgghhh---That would have been really special to have 40psi oil squirted all over the new carpet!
Old Oct 27, 2013 | 01:08 AM
  #84
doorgunner's Avatar
doorgunner
Well..........I started reassembling the console.....and discovered that the $228 Hurst shifter that previous owner installed sat 2" TOO HIGH----the console would not go into place!
Two hours later the shifter "got" bolted to a 2" recessed mounting plate---now the console fits like it should.
Two more hours of installing 2 vent-door cables/heater cable/defroster cable.. ...(had to re-form the wire ends of two OEM cables that had the attaching loops cut off!) an hour went to installing that section of the new wiring harness.
Nothing happens fast on V.A. meds!
I also had to remove some of the wrapping from the new wiring harness after fighting with it for an hour---the manufacturer did a great job of wrapping the wiring---but had it wrapped so tightly that there wasn't enough slack to reach the gauges without the slightest movement during installation causing the dash lights to pop out of their locations--Military helicopters always had several inches of "free wiring" so the gauges could be pulled out and away from the dash for repairs.
Pics tomorrow after everything is finished.
Old Oct 27, 2013 | 11:34 AM
  #85
20mercury's Avatar
20mercury
Default Looks SUPER!!!
Looks SUPER!!!
Congratulations!!!
Really like that black/red combo!!
Drew Brees will be wanting you to take him for a ride in the Quarter and then on to Westwego on the Westbank Expressway and check out all the neighborhood bars along the way! LOL's!!
Old Oct 27, 2013 | 01:37 PM
  #86
doorgunner's Avatar
doorgunner
Originally Posted by 20mercury
Looks SUPER!!! Thanks a bunch!
Congratulations!!! Only waited for the right one 45 years!
Really like that black/red combo!! It was actually an accident...I forgot that the dash and door panels were supposed to match also...Ohh well--the red stands out more this way---I'll add some red dash lights to match the seats/carpet----flashback to military aircraft gauge-lights-red light is easier to look at for hours/doesn't "light-up" the cockpit!
Drew Brees will be wanting you to take him for a ride in the Quarter and then on to Westwego on the Westbank Expressway and check out all the neighborhood bars along the way! No bars for him/work-work-work--He has a SuperBowl to focus on!LOL's!!
I just installed the new wiper switch and ran an independent ground wire to the wiper switch housing at one of the mounting screws (per "tips 'n tricks" in this forum) ---the wiper motor seems to have more power/doesn't slow down when blades change direction----even got the washer pump working even though it isn't "hosed/plumbed" yet.....just need to get the "squirters aimed correctly on the convertible windshield so my eyes don't get "rinsed" when the washer is activated...LOL
Old Oct 27, 2013 | 10:16 PM
  #87
20mercury's Avatar
20mercury
Originally Posted by doorgunner
I just installed the new wiper switch and ran an independent ground wire to the wiper housing at one of the mounting screws---the wiper motor seems to have more power/doesn't slow down when blades change direction----even got the washer pump working even though it isn't "hosed" yet.
After today, I am believing Drew is on his way!
Old Oct 27, 2013 | 11:05 PM
  #88
doorgunner's Avatar
doorgunner
WATCH-IT.....WATCH-IT! Maybe I can get this car going and get a few pics in front of Da' 'Dome!
Sample pic below......B-I-G building...... LOL.....
Old Oct 30, 2013 | 08:06 AM
  #89
doorgunner's Avatar
doorgunner
"Wiring by Bubba"
I found these cut wires hanging out of the bundle, so I added temporary connectors to them to prevent shorts.
These loose wires are all in a separate sub-harness near the wiper motor at the firewall....
Does anybody know where the (2nd wire from left in my hand) sheath-cloth-wrapped steel-strand wire comes from & connects to??????
EDIT: After checking old threads, I found that the sheath-cloth-covered wire was intended to be used on a points-distributor.....the engine has been converted to a HEI dist. , so I'll heatshrink the N/A wire-end closed since it won't be needed.
Brown/White = Wiper door = N/A (door removed previously)
Brown = Wiper motor
Red = Wiper motor
Yellow = Wiper motor/Pump/Door-Limit Switch N/A (door removed previously)
Old Nov 1, 2013 | 03:45 PM
  #90
doorgunner's Avatar
doorgunner
IS IT MY LAPTOP.... or does everyone see huge pics at first---then the pics reduce to normal size?
I've been out of town (RATTTS) ........but got the tach-drive cable from Wilcox f-a-s-t/got the backup light switch......
So...now I'll be able to wrap up the console installation annnnnnd...
all the gauges will be functional!
EDIT: I couldn't control myself....I became a Supporting Member....Thanks to the Members for all the great Info/Support!!!!!
Old Nov 9, 2013 | 09:16 AM
  #91
doorgunner's Avatar
doorgunner
The project has been put on-hold for the last week----
My Son-in law is very sick...(Stage 4 in his liver).
Old Nov 11, 2013 | 06:13 PM
  #92
doorgunner's Avatar
doorgunner
I am setting this day aside for my Son-in-law Jason.
He wanted to buy his first Corvette project-car.
But Destiny had other plans.
Today is their 10th wedding anniversary......
He went to Heaven this afternoon.
Old Nov 11, 2013 | 06:30 PM
  #93
briankeery's Avatar
briankeery
So very sorry for your loss, my condolences to you and your family. Peace be with you brother.
Old Nov 11, 2013 | 07:07 PM
  #94
doorgunner's Avatar
doorgunner
Thanks Brian........he was my daughter's childhood sweetheart.
Old Nov 11, 2013 | 08:57 PM
  #95
roger3's Avatar
roger3
Sorry for your loss.
Roger
Old Nov 11, 2013 | 09:00 PM
  #96
FatCat's Avatar
FatCat
Doorgunner, I am so sorry for your loss brother..
Old Nov 11, 2013 | 09:36 PM
  #97
doorgunner's Avatar
doorgunner
Thanks Men......My wife & I are spending the night at "their" home.....
My daughter is "dodging going to bed".......
They got married when they were 17.
To Doorgunner's '68 Convertible Project
Old Nov 11, 2013 | 09:42 PM
  #98
73 Rat's Avatar
73 Rat
Mike
Old Nov 11, 2013 | 09:47 PM
  #99
persuader's Avatar
persuader
Sorry for your loss. Your son -in-law is at rest now till the lord comes for him and the rest of us. God bless.
Old Nov 12, 2013 | 12:32 PM
  #100
doorgunner's Avatar
doorgunner
He went to Heaven this afternoon (Monday the 11th).
Thanks for the thoughts and prayers----they help a lot. Tomorrow is my Daughter & Son-in-law's Wedding Anniversary...and Funeral.
