1969 rear sway?
Sep 11, 2013 | 02:04 PM
1969 rear sway?
I have a 69 sb. pretty sure im looking for the 7/16" dia rear sway or
9/16".
I have a chance to buy one that look exactly right, but the description claims it's for a 75 to 82 vette?
Can anyone confirm the rear sways were basically the same from -69 to 82?
Sep 11, 2013 | 02:13 PM
A 69 small block shouldn't have a rear sway bar. Only big blocks received the rear sway bar.
Cruise-In II Veteran
All the rear bars were basically the same and install the same way.
Revi: if you ordered the option F41 suspension package with your small block, you got the rear bar.
Sep 11, 2013 | 02:40 PM
Thanks but can you tell me if there was one sway
( I know there were 2 dia) that fit all vetted from 69 to 82
Sep 11, 2013 | 02:45 PM
Besides having two different diameter bars ,
Is the rear sway the same for 69 to 82 vette?
Or was there some kind of design change in 74 ish?
Sep 11, 2013 | 02:54 PM
the listings show 68 to 74 for the factory style bar but what happened in 75 I cannt tell you. The links are the same from 68 to 82. Are you sure what you are looking at is a factory style bar and not aftermarket?
http://www.ecklerscorvette.com/corve...1968-1974.html
Sep 11, 2013 | 03:00 PM
Thanks!
My problem is I have a short amount of time to buy this sway. It's half price of what most want but I'm concerned there was find sort of bad change in 75?
Maybe length? Did the frame change around that time?
Sep 11, 2013 | 03:02 PM
Hi,
This is a later 7/16" sway-bar mounted on my 71.
There weren't any problems installing it.
Regards,
Alan
Sep 11, 2013 | 03:06 PM
Alan you think your sway was from a vette over1975?
Sep 11, 2013 | 03:12 PM
As far as I know, the '75's didn't have a rear sway bar but they offered a front code FE7 bar that was 1-1/8" in diamater. I have one and it is very effective.
Sep 11, 2013 | 03:27 PM
Found this info:
Does this mean the frame was widened 2" and the sway from 75 on would be 2" too long?
'63 to '72 frames remained essentially the same, with minor variations for additional brackets, holes, reinforcements, body mount changes, etc.
'74 chassis were modified with an additional bracket & extension for the rear impact-absorbing bumber.
'75 was again modified with about a 2" wider rear crossmember .
Sep 11, 2013 | 03:45 PM
Quote:
Originally Posted by
CAMS69
...Or was there some kind of design change in 74 ish?...
Only the diameter of the bar and the name of the package. Early it's F41; later it's FE7.
Sep 11, 2013 | 04:13 PM
CAMS69
Found this info:
No, only the last foot of the frame was widened to mount the bumper shocks. Has no effect on the sway bar. All rear sway bars 75-up were 7/16.
Mike
Sep 11, 2013 | 04:37 PM
Hi c69,
My understanding is that in the early years the bb cars used a 9/16" sway bar. Cars with the F-41 option used the 9/16" bar too.
Later years, (after the demise of the bb?), used the 7/16" sway bar.
Regards,
Alan
Sep 11, 2013 | 04:45 PM
The sway bar on my 81 is 7/16".
Sep 11, 2013 | 04:54 PM
Does anyone else think Allen's Car is in his living room?? LOL
Sep 11, 2013 | 05:56 PM
Bought it
Right or wrong it's mine and going on my 69.
http://www.ebay.com/itm/271270194784...84.m1439.l2649
Looks like a great deal for someone at over half price delivered, looks like he has one more....
Sep 11, 2013 | 06:30 PM
Sep 12, 2013 | 02:15 PM
Sep 12, 2013 | 02:42 PM
MelWff
That's to funny!
As we speak I have those parts and others (294.00) sitting in my ecklers kart waiting on a coupon.....
