69 rear key
Old Sep 14, 2013 | 08:10 PM
SB64's Avatar
SB64
Default 69 rear key
My 69 that I'am restoring has a key slot over the corvette letters on the rear. Have not tried my keys yet. Was not sure if it was bubba at work or if this is a stock item maybe for the spare tire?? Anyone
Old Sep 14, 2013 | 08:36 PM
FatCat's Avatar
FatCat
It is how you would set the alarm on the vehicle. If you have the original keys it should be the round one I believe.
Duane4238's Avatar
Duane4238
Try inserting your door key and turning 90*. Then open your door and wait for it. (It's the alarm switch) Consider yourself lucky if it works. It should also go off if you open the hood.
Duane
Old Sep 14, 2013 | 09:11 PM
MakoJoe's Avatar
MakoJoe
The Alarm system is set by the Door Key. I have yet to test mine also in my 1977 the key was were moved to the front drivers side fender in later years. The Alarm system was installed for many years on the Corvettes and the horn is generally installed near the Driver Side Rear Wheel.
Old Sep 14, 2013 | 09:47 PM
Stingraykev's Avatar
Stingraykev
Let us know if it work out for you...
Old Sep 15, 2013 | 12:29 PM
SB64's Avatar
SB64
Default rear key
Okay tried both keys N/G why because there is a broken key in there.
Now what
Old Sep 15, 2013 | 01:30 PM
c3_dk's Avatar
c3_dk
Now what
http://www.ebay.com/itm/NOS-1968-1969-1970-Corvette-alarm-switch-with-Briggs-Stratton-key-/380706744216?pt=Vintage_Car_Truck_Parts_Accessories&hash=item58a3e3e798&vxp=mtr
Old Sep 15, 2013 | 08:13 PM
SB64's Avatar
SB64
Default rear key
okay c3 thanks for pic on key tumbler will have to get if I can't come up with a way to fix. trying a powerful magnet, oh well $35. is worth it
Old Sep 15, 2013 | 10:12 PM
russianhomie119's Avatar
russianhomie119
you could try buying a cheap key extractor. they cost $5 or try to make one that will work out of a small paper clip
Old Sep 15, 2013 | 11:17 PM
Duane4238's Avatar
Duane4238
I tried something a little different to get a broken key out of a car door lock and also the lock on my freezer. It worked both times, too. Use a dental pick to hold the little door cover open, then put a very, very tiny drop of Crazy Glue on a paper clip. Put it in the slot against the broken key and hold it very still for a couple of minutes until it's dry. Then carefully and slowly pull straight out. All you have to do is get it out far enough to grab it with some needle nose pliers and you're home free. Good luck!
Duane
Old Sep 16, 2013 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...My 69 that I'am restoring has a key slot over the corvette letters on the rear. Have not tried my keys yet...
It's the optional factory alarm. It arms and disarms with a small key (possibly says Briggs and Stratton on it).
Old Sep 16, 2013 | 03:29 PM
kjr6306's Avatar
kjr6306
I tried to replace this on my 1970 and the alarm switch listed above did not fit. The hole was too big. Are there 2 different versions of this part??
Old Sep 16, 2013 | 04:00 PM
Red Vert 02's Avatar
Red Vert 02
Yes there are 2 different versions of the alarm lock. mid '68 to mid '70 used the lock pictured. It has no door in the key way and locks would fail due to dirt entering the keyway. In mid 70 a lock entered production that looks just like the door lock. It had the door protecting the key way and used the round head key that also worked the glove box and spare tire lock. When this lock was used to replace the earlier lock the hole in the tail panel had to be enlarged.
Old Sep 16, 2013 | 04:13 PM
Crafty12's Avatar
Crafty12
Most part sites list an early 70 and a late 70 alarm lock.
Old Sep 16, 2013 | 04:49 PM
Kevin68's Avatar
Kevin68
.... trying a powerful magnet, ....
The key is brass. The magnet won't work.
Old Sep 16, 2013 | 05:08 PM
MelWff's Avatar
MelWff
remove the cylinder and take it to a locksmith
Old Sep 16, 2013 | 05:45 PM
jhudec's Avatar
jhudec
Default rear key lock
If the OP does not have another Briggs key, no use messing with it. Just purchase the replacement. The only thing that the Briggs key was used for was the alarm lock.
Old Sep 16, 2013 | 09:28 PM
russianhomie119
a locksmith charged me $25 to make me a key for my tool box lock. He could remove the broken one and make you a new one if you want to keep the original cylinder
To 69 rear key
