How to remove tape stripes?
Old Sep 15, 2013 | 11:33 AM
rwrawls's Avatar
rwrawls
Default How to remove tape stripes?
PO used tape for the hood stripes on SA '78. Not a bad job but I would like to replace them with a OE decal. Need recommendations on removing tape without destroying paint on hood.
Old Sep 15, 2013 | 11:37 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I'll start with a SERIOUS warning to test this on a hidden area first. I used this on a car with bad paint so I didn't notice any harm. Use at your own risk!!!
Easy Off oven cleaner. Lifted the stock decals off of my 81 like they were surface dust.
Old Sep 15, 2013 | 11:38 AM
FatCat's Avatar
FatCat
Not positive ( someone will know for sure) I would think warm them a little with a heat gun and pull them up carefully.
Scott
Old Sep 15, 2013 | 11:41 AM
Roco71's Avatar
Roco71
Heat gun is one method and then Fabulous Blaster makers of PB Blaster make a decal/sticker (DSR) remover.
Old Sep 15, 2013 | 11:50 AM
Sunstroked's Avatar
Sunstroked
No way I would use a chemical not designed for use on auto paint.
I have removed stripe tape using a hair dryer. It doesn't get as hot as a heat gun. Unless you have a heat gun that you can adjust the temp. Save your paint and borrow the wife's hair dryer. More than likely, the untaped paint will have faded. Leaving the outline of where the tape was. A good quality rubbing compound will help blend it.
Old Sep 15, 2013 | 11:53 AM
FatCat's Avatar
FatCat
Sunstroked is is right a hair dryer would probably be better.
Old Sep 15, 2013 | 01:22 PM
SS164's Avatar
SS164
Electric heat gun. That's how the all the woodgrain decals on station wagons were removed back in the day.
Old Sep 15, 2013 | 01:29 PM
noonie's Avatar
noonie
Depending on how long and how much exposer, you find the paint under the stripes a different color from not fading. If so, buffing might remedy that.
The above mentioned removal methods are all good. Personally, I use oven cleaner, it works well even with painted on stripes.
Old Sep 15, 2013 | 03:19 PM
dochorsepower's Avatar
dochorsepower
I removed some stripes once using hot water poured from a tea kettle. The paint underneath will probably be a different shade.
Old Sep 15, 2013 | 03:24 PM
esierra's Avatar
esierra
Allot depends on the age and condition of the Vinyl stripe, Natural sun first (on hot day), Heat gun second being careful. Never had much patience for a hair dryer, To much heat and its hard to pull the Vinyl off in large sections. For old dried out Vinyl there's a round wheel eraser you put on the end of a power tool. Work well for me on a Corvette I had, Does make a little bit of a mess as the eraser fly's off.I also used a lil chizler tool to pick up and lift Vinyl.
http://www.lilchizler.com/
Old Sep 15, 2013 | 06:27 PM
jnealg's Avatar
jnealg
Start with a hair dryer on low blow hi heat it should peel off then an adhesives cleaner graduate to a heat gun if needed. Just not too hot or too long to bubble the paint
Old Sep 15, 2013 | 08:35 PM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Used to detail cars and had someone paint stripes for me - always used hair dryer to remove old tape stripes - much safer. There could be times when you should use a heat gun, but hair dryer will do the trick most times.
Old Sep 15, 2013 | 09:23 PM
alswagg's Avatar
alswagg
Makita heat gun. Al
Old Sep 16, 2013 | 08:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have your replacement OE stripes on hand before you start removing anything. The OE is difficult to find.
Old Sep 16, 2013 | 12:22 PM
7T1vette's Avatar
7T1vette
Only a pro that is very adept at using a [hi-temp] heat gun should try that approach. For us 'everyday DIY' folks, a hair dryer would be best...much less risk of bubbling any paint.
I would only use a 'tape softener' (chemical substance) if the tape were so old and brittle that hair dryer heat would not allow easy removal.
Old Sep 17, 2013 | 01:34 PM
Rally68's Avatar
Rally68
I used a hair dryer and a scraper with plastic razor blades; worked like a charm.
I was taking pinstripes off a Suburban...looong pinstripes. The wife's hair dryer did not survive the operation. I don't have to tell you how that turned out.
Old Sep 17, 2013 | 06:15 PM
7T1vette's Avatar
7T1vette
If you use a hair dryer, after using it on "Hi" heat, you must turn the heat setting to "cool" while the dryer is still running. This cools off the heating elements so that they don't just melt due to lack of airflow over them. After about 30 seconds you can turn it to OFF with no problem.
To How to remove tape stripes?
Old Sep 18, 2013 | 09:19 AM
Rally68's Avatar
Rally68
NOW you tell me!
Old Sep 19, 2013 | 04:52 PM
rwrawls's Avatar
rwrawls
Thanx for the help and recommendations. The hair dryer worked great and I returned it to the wife still in working order. I looks like the clearcoat was applied over the tape so there are lines in the paint and some discoloring. Looks like I'll have to have the hood repainted. I've been told the silver paint may be hard to match.
Old Sep 19, 2013 | 04:56 PM
7T1vette's Avatar
7T1vette
I think a good paint shop could fix that lack of clearcoat pretty easily...without having to repaint the hood. If the area below the stripes is a different color than the 'exposed' paint, that's another story.
