Brake squeal
Old Sep 15, 2013 | 10:17 PM
1978vett's Avatar
1978vett
Default Brake squeal
The right rear brake in my 78 started squealing when I would apply the brakes ,,,today it started squeaking all the time and when I put the brakes on it changed to a higher pitch squeal as soon as I let off thr brakes it changed to a lower pitch squeal.. Pads and roter is all good.. What is going on ?? Thanks
Old Sep 15, 2013 | 10:48 PM
russianhomie119's Avatar
russianhomie119
is there any drag when you let off the gas? or pull to one side?
Old Sep 15, 2013 | 11:00 PM
1978vett's Avatar
1978vett
No there is not any noticible drag ,,
Old Sep 15, 2013 | 11:22 PM
RedRedRed's Avatar
RedRedRed
Parking brake shoes?
Old Sep 15, 2013 | 11:27 PM
1978vett's Avatar
1978vett
I have no idea
Old Sep 15, 2013 | 11:36 PM
tokim's Avatar
tokim
Often the misconception, is the squeel is caused by dust/glazed pads..more often than not it is caused by vibration.
When replacing disc pads, it is advisable to also purchase the disc brake harware kit as well, consisting of new clips, etc.
They make a disc brake quiet spray (it works temporarily if the pads are glazed), and they also sell a product that is similar to silicone for the back of the pads, to help absorb that vibration, as well as stick on brake shims.
Old Sep 16, 2013 | 12:27 AM
PeteZO6's Avatar
PeteZO6
You can try to remove the pads and file or grind a 45* chamfer or bevel on the leading and trailing edges of the braking material. This can reduce vibration caused brake noise. Doesn't cost anything other than your time.
Pete
To Brake squeal
