76 radio
Old Sep 16, 2013 | 03:36 PM
Russ W's Avatar
Russ W
Default 76 radio
I am looking to replace my 76 radio... I currently have an aftermarket radio. Previous owner cut a hole to make room, etc. I have a new center gauge cluster and want to put a stock looking radio in without breaking the bank. any recommendations? thanks...
Old Sep 16, 2013 | 04:16 PM
MelWff's Avatar
MelWff
Have you looked at these
http://www.classiccarstereos.com/cat...tte-Radio.html
Old Sep 16, 2013 | 05:29 PM
Marty913's Avatar
Marty913
I paid around $160 for a Custom Audio Sound. So far it has been fine (couple months). Same one as mentioned above by MelWff.
Old Sep 16, 2013 | 10:12 PM
lvmyvt76's Avatar
lvmyvt76
You can have your stock radio changed to hook up the newer electronics like mp3 etc.
Old Sep 16, 2013 | 10:20 PM
russianhomie119's Avatar
russianhomie119
what do you mean?
7T1vette's Avatar
7T1vette
If I understand you correctly, you do not have the "original" Delco radio. If correct, then, "No", you can't get it to original condition without 'breaking the bank'.
A '70-77 Delco radio will cost you anywhere from $150-300 just for a non-functional, but complete, radio head unit. You also need to have a matching 'convector' unit to act as the final stage of amplification for the radio. The head and convector are either a "monaural" unit or a "stereo" unit.
Once you have a decent 'slave' radio head, it needs to be fully restored and that will cost you another $400-700, depending on what radio you have and what you want done. As mentioned above, some restoration shops can install modern electronics in the stock head unit and make it fully functional and better performing than the '70 vintage radios. This is a very good way to go, if you are not a stickler for "completely stock". But, that will cost you about $400, also.
Then, you need to get speakers of matching impedence to whatever radio unit you purchase. In total, you will spend $800-1000 to obtain a well functioning 'original' or 'upgraded' stock-looking radio head.
Old Sep 17, 2013 | 11:58 AM
1977L48's Avatar
1977L48
I have an original delco AM/FM out of a 73 monte carlo, untested, ide be willing to sell.
Old Sep 17, 2013 | 12:17 PM
7T1vette's Avatar
7T1vette
Not the same opening dimensions for the Monte Carlo...is it?
Old Sep 17, 2013 | 12:24 PM
1977L48's Avatar
1977L48
the corvette uses a "staggered" face correct? where face for the right **** is deeper than the left? let me go grab it.
Old Sep 17, 2013 | 12:33 PM
1977L48's Avatar
1977L48
ok, I have the one out of the 73 Monte Carlo BUT my vette isent here right now. but from when ive pulled out the AM/FM 8-track out of my vette to replace the belts on the 8-track player they look the same. the monte has a black face on it with silver lining around the band indicator, and the one in my vette is completely silver, same with my 77 Monte Carlo with an AM/FM 8-track player in it
Old Sep 17, 2013 | 01:17 PM
nodebtvette's Avatar
nodebtvette
I have a working AM/FM 76 Radio if you are interested (with stock amp). PM me if so.
Old Sep 17, 2013 | 01:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FYI: will not fit Corvette.
Old Sep 17, 2013 | 09:30 PM
Russ W's Avatar
Russ W
I may go with the 160.00 radio above, I'm already into this car enough$ I do not have a stock radio but could have purchased a bench tested stock one for 150.00 a while back. I think the one above will look good with my new guage cluster.
Old Sep 19, 2013 | 03:55 PM
Russ W's Avatar
Russ W
I also have grey interior...whats with the chipped pain on iside of radio
Old Sep 20, 2013 | 07:23 PM
Marty913's Avatar
Marty913
Where? Might be bad picture taking.
Old Sep 20, 2013 | 07:44 PM
Russ W's Avatar
Russ W
Looks like paint is missing on inside, has a brown look to it, all good, I ordered anyway
Old Sep 21, 2013 | 09:03 AM
Marty913's Avatar
Marty913
I think the camera flash screwed it up. It's pretty much all black & chrome. Here's another angle.
Old Sep 23, 2013 | 02:20 PM
Russ W's Avatar
Russ W
its like looking at my own car...I even have the same rug mats. Can't wait to clean up htat area with new radio and center guage cluster..radio should be here in a day or two.
how do I attach photo? its looking for a url address
Old Sep 23, 2013 | 07:33 PM
ZekerC79's Avatar
ZekerC79
Cruising
Give ebay a try. I found an '76 radio in great condition on ebay to replace an aftermarket radio in my '79. I "bought it now" for $160. Had to change the ***** and get a new gage cluster bezel. It works and looks great.
To 76 radio
