Since you say you're getting 12V at the headlight switch (you did verify that, right? ), manually apply 12V to the wire that feeds the gauge lights (the one that attaches to the headlight switch) and see if the lights come on. Basically, do what BDoc advised and start working your way down the wiring until you find the break.
Which wire feeds the lights?! Yes, getting power to the switch, from the red wire. The red wire comes ( I believe) from under the armrest and back to the battery?
Unfortunately, none of the documentation I have shows the wire color.
You should be able to use your voltmeter on the headlight switch tabs that the wires connect to and find the one that changes as you rotate the switch ****.
Unfortunately, none of the documentation I have shows the wire color. You should be able to use your voltmeter on the headlight switch tabs that the wires connect to and find the one that changes as you rotate the switch ****.
Find a good ground and 12v from other wires using a multimeter. There's like 25 of each in the wiring harness there. You'll have no problem finding them. If nothing else, take some six foot long wires with alligator clips and just go the battery.
Then, one at a time, supply 12v to the light (you might have to splice in to the wire a little) and see if it comes on. If it does, you know you're missing 12v (switch, fuse, or wiring problem.) If that doesn't make it come on, supply ground (attach the ground wire to the little metal clips that surround the bulb.)
In this manner you can see if the problem is 12v or ground. If it turns out to be 12v check:
- Fuse
- Switch (manually input 12v to the switch harness to rule it out)
- Wiring (use the continuity feature on a multimeter)
If the problem is ground, it's a loose or cut wire somewhere.
Here is a pic if my connection to the switch. What goes in the empty slot that was burned? Something, right? A ground? The diagram shows a dot, but no wire.
The one with the mark here powers the dash bulbs on my car. I think the harness just gets hot, I'm not sure it necessarily indicates a short that it's discolored.
Does it really matter if your lights come on anyway?
Just do this: Run a temporary 12v there with a manual ground supplied to a bulb. Does it come on? Great. Keep the 12v there. If not, repeat the process with a ground. Very simple man
Progress.. Manually supplied power to center gauge light cluster (sliced one of the light (gray) wires. Boom, lights! So I'm obviously not getting power to them through the harness.. Also, now I have no running lights or side markers.. But the front side markers blink with the turn signals.
Also, a few of the bulbs need a manual ground to light up. Should a wire brush do the trick or does anyone have a different remedy?
Now that I know I'm not getting power from the harness (power for these is still supplied through the headlight switch right?), what is my next step?
Also, now that I have everything back apart, I have noticed bubba has been in my car at some point. (Probably when I had a stereo and alarm put in 10 years ago?). So, thats part of my issue I think. I have a few things not plugged into anything. For example, right by the fuse box, a purple wire with a plug.. Just hanging out. Also, a wire that travels under the arm rest that has two white wires, a purple, and (trying to remember now), possibly black, also not plugged into anything.
Try manually supplying power to the harness on the spot marked in my picture. That should make the lights light up as well. If it does, you probably need a new switch. If it doesn't, you have some wiring issues in between the harness and the lights.
As to the ground, I'm not sure there. The little metal prongs probably aren't touching the light bulb correctly would be my best guess. You might want to buy some new bulb connectors.
Get yourself a wiring diagram. It will be money well spent. There's a few different things in the center arm-rest console. It could just be one of the dome lights there.
Nope, not yet. The spot marked on the harness is where the red wire is, and I am getting power there. Also, my switch is brand new, so it should be working properly. What if I fee the gauges power from the radio, so when the cars turns on y gauges are all on automatically?
That could work!
You may need a switched 12 feed.
LED's must receive full 12 volts for them to work.
You cannot dimm them with the rheostat. They will be on or off only.
Your center gauge cluster has a good ground or the gauges would not work.
BDoc suggested applying 12 volts to the dark green and if the lights work then the wiring from the switch connector to the bulbs is good.
Here's a diagram, it shows what each wire does when it gets 12 volts.
To get full voltage to the rheostat turn it full CCC and come back CW to the click.
