PLEASE help!! Gauge lights not working.
Old Sep 21, 2013 | 07:52 PM
Killingsworth 73's Avatar
Killingsworth 73
Default PLEASE help!! Gauge lights not working.
I have my interior out - to replace the gauge lights with LEDs, replace my headlight switch, and install an electric tach.
Tested the tach - it works.
Test the lights before I put everything back together, and no lights (EXCEPT the turn signals, "BRIGHTS", and "BRAKE". None of the center gauge lights, or speedo/tach lights come on. Used my voltmeter on the light switch coil and ground, and it's running 12v. Checked the fuses - they're good.
This was the main reason I took all this stuff out! Please help, let me know what to do. I still have the interior out to troubleshoot. I don't want the answer to be "buy a $500 dash harness".
Thanks everyone.
Old Sep 21, 2013 | 10:03 PM
oldalaskaman's Avatar
oldalaskaman
make sure you have a good ground , then make sure the power wire to the lights is connected
Old Sep 21, 2013 | 11:30 PM
Killingsworth 73
As best I know, both are supplied by the connector plugged into the light switch. There is also a ground to the metal on each the tach and speedo. Not sure if there are others.
Old Sep 22, 2013 | 12:02 PM
7T1vette's Avatar
7T1vette
Ground to the speedo/tach has nothing to do with the center gauge cluster. It has a separate ground via the trans tunnel route. Use a piece of 'dummy' wire to link a known-good grounding point to the chrome surface [edging] on the gauge cluster and turn on the light switch. If the gauge lights come on, there's your problem.
Old Sep 22, 2013 | 12:35 PM
Roco71's Avatar
Roco71
I believe the center black wire (68-76) on the temp gauge is also a source for the ground to the gauge cluster.
Peterbuilt's Avatar
Peterbuilt
Default You checked the instrument fuse, yes?
The ground for the "center gauge cluster" starts at the center terminal of the water temp gauge and connects to the bird cage just above the bottom of the dash.
Old Sep 22, 2013 | 08:32 PM
Killingsworth 73
Anyone know which wires have to be grounded for the speedo and tach lights?
Old Sep 22, 2013 | 08:35 PM
7T1vette's Avatar
7T1vette
The back of each housing has a (black) ground wire connected to it.
It is still very easy to touch ground to the gauge bezel to see if grounding is an issue, or not.
Old Sep 22, 2013 | 09:01 PM
Killingsworth 73
Just making sure it's those two. I am going to connect all 3 to 1, and set it to the kick panel. I'll keep you guys updated. Thanks! Just wanted to make sure those two were the wires I needed. They don't need to ground to the actual housings right? Just to the harness?
Old Sep 22, 2013 | 09:29 PM
Peterbuilt's Avatar
Peterbuilt
On this schematic the speedometer, the tachometer, the center gauge cluster and the black wire from the water temperature gauge are the same wire.
http://www.vetteprojects.com/bmv/mis...tte%201973.pdf
Old Sep 22, 2013 | 09:59 PM
Killingsworth 73
Hmmm... Because all my gauges work, including the water temp, but no lights. On the back of each metal housing (speedo and tach) there is a black wire that goes into the dash harness bundle of wires. Didn't look for the center console one yet. Hopefully tomorrow I can test this all out.
Old Sep 23, 2013 | 09:00 AM
BDoc's Avatar
BDoc
- Have you manually supplied ground to verify it IS a ground issue?
- Do you have the headlight knock rotated so that all lights are turned on?
- Manually supply 12v through the headlight wiring harness to rule out a switch issue
- Manually supply 12v and ground to various lights to rule out both 12v and ground issues
I just got through doing all this myself actually, and it turned out to be a combination of several of the above issues
Old Sep 23, 2013 | 04:20 PM
Peterbuilt's Avatar
Peterbuilt
Default A few easy things to check
The "Tail light" fuse feeds the headlight rheostat so make sure it's good and that the K N O B is full CCW or the K N O B is pulled out.
If the lights are still out jumper from the "courtesy light" fuse to the "instrument light" fuse.
If the bulbs light then the rheostat in your new switch is bad.
Old Sep 28, 2013 | 05:09 PM
Killingsworth 73
I don't understand how to read the wiring schematic.. The part of the harness that connects to the headlight switch has been burnt to some degree.. The plastic is black and brown on part of it, where the two connect, instead of whitish. I tried manually supplying a ground and no luck. **** is pulled and turned the correct way. So frustrated right now. Tested the burnt part of the connection and it is still running 12.5v. My headlights etc are all coming on still, just not my gauge lights.
Old Sep 28, 2013 | 05:50 PM
BDoc's Avatar
BDoc
Did you rotate the headlight **** all the way to engage the gauge lights? Do that, then manually supply power and ground to an individual light to see what's missing
Old Sep 28, 2013 | 06:05 PM
corvette_maniac's Avatar
corvette_maniac
I just went through all of this on my `75. Since NONE of them are working, double check the ground that goes to the instrument cluster. Notice that all of the gray wires only have one wire. The ground comes from the ground supplied to the instrument cluster to complete the circuit. If the ground is good, check the voltage to the gray wires that feed the lamp sockets. If you have no voltage, then either you have a blown fuse, 12V not switching through headlight switch or the headlight switch's rheostat is not turned far enough counter-clockwise.
Old Sep 28, 2013 | 08:13 PM
Killingsworth 73
Supplied a good ground to the black wire coming out of the harness and no change. How could I wire these lights to a simple switch?
To PLEASE help!! Gauge lights not working.
Old Sep 28, 2013 | 09:15 PM
VCuomo's Avatar
VCuomo
Just my $.02, but you should find out what's wrong and correct it. Don't do a Bubba fix.
BDoc has it right, follow his advice. Since you say you have definitely supplied a good ground, try manually supplying 12V to them and make sure the lights come on. Then use a voltmeter on the headlight switch's 12V feed to the gauge lights and see if there's any output - I bet there isn't.
Old Sep 28, 2013 | 09:21 PM
Killingsworth 73
How do I supply ground and power to an individual light? They only have the one wire. The ground wire in the harness comes out (I believe) 3 times. I have attached one to a known ground. That should solve that right? Where can I get the 12v power from?
Killingsworth 73
Also, the **** is rotated all the way counter clockwise.
