Brake bleeding...No fluid through any bleeder
Old Sep 22, 2013 | 06:07 PM
runningstart's Avatar
runningstart
Default Brake bleeding...No fluid through any bleeder
My first time bleeding GM brakes.
I have all 4 calipers replaced and the master cylinder and SS brake lines.
I get no fluid through any of the lines either gravity bleeding or with a Mighty Vac pulling up to 20 inHg.
Ideas?
Old Sep 22, 2013 | 07:08 PM
my 76 ray's Avatar
my 76 ray
Did you try the mighty vac on both the front and rear? If the valve in the distribution block is tripped and you tried only the side that it closed off then that could explain it.
Old Sep 22, 2013 | 07:20 PM
mrvette's Avatar
mrvette
IF you have OEM style lip seals on the caliper pistons, you can not use a vacuum system very effectively, but if you had the foresight to install a O ring caliper setup....presumable stainless like any thing today....you can still push fluid down the system....the cheap way to do this is, note the stock stamp steel like and the rubber seal up top of the m/cyl....
fill the thing with fluid, and drill a hole into each cyl section....1/16th is fine....this obviously has to be above the rubber seal.....
so put the lid on, and hit it with your air hose, not the small tip but the large blaster tip into that small hole, we not trying to blow the damn lid off, but put pressure on the m/cyl to fill the lines....and brakes, one end of the car at a time....keep a check on the amount of fluid in the m/cyl, so not to blow air too much at a time.....and empty the m/cyl and push air into the lines.....
I assume you know about the bleeder valves on the calipers.....
Old Sep 22, 2013 | 07:26 PM
vairxpert's Avatar
vairxpert
You did bench bleed the new master cylinder, right?
C3 4ME's Avatar
C3 4ME
Did you happen to put a new master cylinder on and if so, did you bench bleed the master cylinder first?
Old Sep 22, 2013 | 08:31 PM
7T1vette's Avatar
7T1vette
If your flex hoses (between each hard line and caliper) have many years on them, they could have deteriorated at the inside of each hose, making it difficult to pass fluid. Since you are doing a brake system refurb, you really need to change those out, unless you have done so recently.
Old Sep 23, 2013 | 12:05 AM
runningstart
These are new Wilwood brake calipers to answer the question about the calipers.
Mighty Vac all 4 corners.
Yeah, I did install a new master cylinder and did bench bleed it, however, it is possible it lost some of the bleed when I installed it and didn't have the lines tight enough and could have sucked in air when I pumped the brake pedal as the connections leaked a little until I realized they were loose.
There are still rubber lines on both fronts and rear on 1 side, I put full stainless steel on 1 rear, but on the other rear I left the rubber line because I was tired of fooling with it and didn't want to round off the connector (it was being real stubborn). The fronts are pretty stubborn too so I just left the rubber lines between the hard lines and the new SS lines that connect to the calipers.
CORRECTION: The fronts are stainless steel lines directly from the hard lines to the calipers, so there is only 1 rubber line remaining in the whole system at one rear corner.
I'm thinking rebleed the master, but also the possibility of something having to do with the proportioning valve.
How do I reset the proportioning valve?
Old Sep 23, 2013 | 01:24 AM
ddawson's Avatar
ddawson
Typically on Wilwoods there are two screws.
The larger one is an adapter and the small one the bleed screw. Make sure you are just turning the bleed screw.
In this shot the black screw not the brass one.
Old Sep 23, 2013 | 02:22 AM
runningstart
Ah ha! I think you nailed it ddawson! I've been cracking the brass screw.
Next chance I get I'll open at the black screw. Damn old eyes!
Old Sep 23, 2013 | 10:47 AM
Todd TCE's Avatar
Todd TCE
Supporting Vendor
Good tips above. However ideally the calipers should be in a vertical manner for bleeding. Using the vac or any other tool will not guarantee the crowns of the pistons are fully purged. Only having the nipple at the top will as the air will rise to the highest spot.
Old Sep 23, 2013 | 11:35 AM
ddawson's Avatar
ddawson
I did the same thing when I installed the GTO kit.
I finally figured it out when I used a cheap vacuum bleeder and had vacuum with one pump.
I felt like the V8 commercial were you smack your head.
Old Sep 23, 2013 | 12:23 PM
runningstart
Good point! Easy enough to remove a mounting bolt and rotate the caliper to vertical, but thanks for the reminder.
Old Sep 23, 2013 | 12:35 PM
929nitro's Avatar
929nitro
I have never had to remove a mounting bolt to bleed brakes. Just make sure on the back calipers you do both inside and outside bleeder screws. I believe sequence is inside first and then outside.
Old Sep 23, 2013 | 02:06 PM
runningstart
Just confirmed ddawson's suggestion was the solution. Thanks to everyone for your input. Almost have this beast roadworthy.
Old Sep 23, 2013 | 06:19 PM
Todd TCE's Avatar
Todd TCE
Supporting Vendor
If the stock calipers have bleeders on the tops of the piston crowns (as I think they do) that's why you didn't have too. These don't have that option. You did look at the picture above right?
Air being air...will become trapped at the high point. Bleeders are at 9 and 3 whereas the crown of the piston is at 12. Obviously this is all because the calipers are laid over and not vertical.
Old Sep 24, 2013 | 08:26 AM
929nitro's Avatar
929nitro
Thanks. I did look at the picture but I guess not close enough, I was thinking it was taken at an angle but after looking again I see I was wrong.
To Brake bleeding...No fluid through any bleeder
