Brake Sqeak
Old Sep 25, 2013 | 03:38 PM
1978vett's Avatar
1978vett
Default Brake Sqeak
My 78 has got a squeak from the right rear wheel area.. Its sounds like sqeak sqeak sqeak etc. until I push on the pedal then it changes to a higher pitched sqeak sqeak ... It doesn't do it until I have driven for a few miles then it doesn't go away until the car has set for a while.. Any info would be great ,,thanks
Old Sep 25, 2013 | 03:49 PM
MelWff's Avatar
MelWff
check the u-joints, the wheel bearings, and the brake pads.
Old Sep 25, 2013 | 04:44 PM
1978vett's Avatar
1978vett
If it were u-joints would the sqeak sound change when I put the brakes on ?
Old Sep 25, 2013 | 05:15 PM
Brcmpbl's Avatar
Brcmpbl
In theory yes, if there is play when you apply force to the area by pressing on the brake pedal it could change the position of various parts just very slightly, thus changing the sound. Ditto the bearings and play.
I'd guess that what you have is uneven brake pad wear. The pads are constantly in contact with the rotor as you drive, so a high spot can cause this kind of squeak, etc.
What's causing the uneven wear, that's the question likely. Could be rotor run out, which is common, and / or could be play somewhere further. Need to look around.
Old Sep 25, 2013 | 06:59 PM
havesometo's Avatar
havesometo
Mine made the exact same sound. It was a bent spindle.
Old Sep 25, 2013 | 08:17 PM
mds3013's Avatar
mds3013
Rotor run out seems to be the main reason. As the rotor moves in and out it contacts and retracts from the brake pads causing the squeak. When the brakes are applied the squeak stops as the pads are tight against the rotor. How I stopped mine, replaced rear rotors due to damage on the inner parking brake hub, spindles checked for run out and none found, had front rotors turned by a very experienced Tech. that removed less than .020 per side, new organic pads. Noise is gone now for three years. Good luck with it, mike...
Old Sep 25, 2013 | 10:50 PM
1978vett's Avatar
1978vett
What would cause a bent spindle?
Old Sep 25, 2013 | 11:16 PM
havesometo's Avatar
havesometo
Maybe a previous owner hit a pothole or curb. And it act just like rotor run out.
Old Sep 26, 2013 | 09:34 AM
1978vett's Avatar
1978vett
Ok, thanks everyone for the info..
To Brake Sqeak
