seat back alignment issue
Old Sep 27, 2013 | 04:29 PM
jnealg's Avatar
jnealg
Default seat back alignment issue
my drivers seat has started having an issue with the alignment of the upper adjustment bolts and the lower.
When the seat is back the upper bolts seat in front of the lower ones. Is this a common issue? will this fix it? http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
I assume the lower back frame has bent but it feels solid. I tried to grab one of the upper bolts and see if it was weak and would bend back in place. I couldnt move it.
Is there a better fix short of replacing the seat?
Old Sep 28, 2013 | 09:57 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
In most cases that bracket will fix the seat frame if there is rust or damage. But I've seen plenty of them that just had a weld broke in the frame and not need that plate at all. While it may seem solid to you, the fulcrum of your weight on the seat back is very capable of bending the frame.
You may want to peal the seat cover back a bit and see what it looks like before you do anything.
Willcox
