4 speed Question?
Old Sep 29, 2013 | 02:28 PM
Rumbles1960's Avatar
Rumbles1960
Default 4 speed Question?
I have had my 79 for a week now, I absolutely love the 4 speed and the car shifts very well. Question is other 4 speed cars I have owned have always had a spring or something to align the shifter with first and second if I remember correctly when it is in the neutral position. My shifter will just stay where you leave it in the neutral position. It's not sloppy of tight feeling, so if this is not how it is suppose to be what are your recommendations to fix it? Thanks
Old Sep 29, 2013 | 02:33 PM
F22's Avatar
F22
Your experience is normal. I rebuilt mine and it's just like that, you can rattle it around in neutral and the only memory it has, is in your brain!
Old Sep 29, 2013 | 05:17 PM
Rumbles1960
do Hurst shifters have a different feel to them?
Old Sep 29, 2013 | 05:28 PM
Duane4238's Avatar
Duane4238
Yes. I had a Hurst competition plus in my Camaro. It's a completely different feel. It's spring loaded and kind of pops from gear to gear.
Duane
Old Sep 29, 2013 | 08:55 PM
Rumbles1960
Duane
Sounds like the right shifter for me and the one I must have had in my 79 Z 28. I don't care for the stock one.
Old Sep 29, 2013 | 10:06 PM
Sunstroked's Avatar
Sunstroked
My shifter also has no real spring action that moves it towards the 3-4 gate either. Trans is rebuilt and shifts flawless, I disassembled, cleaned, inspected, and reassembled the stock shifter. Its smooth enough.
I have a hurst shifter too, had it in the car, the 4 fwd gears have a nice positive short throw. The reverse, is a bit awkward to get into compared to the stock shifter. I removed the hurst unit and put the stock one in for now.
Old Sep 30, 2013 | 08:11 AM
Rumbles1960
How is reverse achieved with the Hurst shifter? Last 4 speed car which was a Z 28 I had to lift the shifter up and over to reverse.
Old Sep 30, 2013 | 08:20 AM
John 65's Avatar
John 65
Hard left then forward.
Its a great shifter, selfs align and practically goes into 3rd for you. You can even bolt a vette style shifter to it to look correct if you desired.
Old Sep 30, 2013 | 09:58 AM
1977L48's Avatar
1977L48
ide go with a Hurst comp or Indy shifter, they have stops on them as well that lets you know when you are in that gear. and its just cool to me to say "yeah, its got a Hurst"
Old Sep 30, 2013 | 12:51 PM
Rumbles1960
what handles are you guys using on your HURST shifters? Straight, curved, offset? I sit with the seat all the way to the back so I am thing a slight curve would work better for me instead of straight.
Old Sep 30, 2013 | 12:53 PM
Priya's Avatar
Priya
I had a Hurst Super Shifter II in my 70 Torino. It was spring loaded and sat at the 3/4 gate unless you pulled it towards the 1/2 position. It was very precise and it was just "click", "click", "click" to shift gears - loved that shifter.
Old Sep 30, 2013 | 05:50 PM
jnealg's Avatar
jnealg
I have always liked the feel of the T handle in my hand. I have one on the vette.
I use the straight shifter but one with a slight curve would be nice. I couldnt find one with just the right ammount. I am going to heat mine up and bend it a bit one day.
Old Sep 30, 2013 | 07:24 PM
Rumbles1960
Can anyone recommend that just right shifter stick for our 4 speed C3's?
Old Sep 30, 2013 | 07:27 PM
Priya's Avatar
Priya
My guess is that because most people are happy with the factory short straight shifter stick that that is the "just right" shifter stick for a C3.
Old Sep 30, 2013 | 07:32 PM
John A F's Avatar
John A F
I have the straight Hurst shifter on my '79 with a cue ball shift ****. it's perfect.
[IMG][/IMG]
Old Sep 30, 2013 | 07:56 PM
C3 4ME's Avatar
C3 4ME
My Hurst shifter set up is pretty much exactly as shown on the 79 above. A straight stick with a white 4spd pattern shift ball.
Old Sep 30, 2013 | 08:31 PM
Rumbles1960
when you buy the Hurst Competition shifter do you need the installation kit? It's confusing because they say no vehicle modifications necessary in the shifter description.
Old Sep 30, 2013 | 09:01 PM
Lupigiato's Avatar
Lupigiato
I have a Hurst Competition Plus shifter - short stick.
To 4 speed Question?
