A/c charging
Old Oct 4, 2013 | 04:18 PM
4 speed's Avatar
4 speed
Default A/c charging
When I got my 73 the AC won't engage. I got the heat/AC control working and found a missing ground on the compressor.
now everything is working except it's not getting cool. if I push on the little charging valve by the compressor , it releases pressure.
does this mean the system just needs charged?
also i have a couple can of 134, can that be used on a 73 system ??
Old Oct 4, 2013 | 04:42 PM
Roco71's Avatar
Roco71
Unless your system has been converted to r134a it has r12 in it. You can not mix r12 and r134a together. When a compressor is low on refrigerant it should not kick on so as to prevent it from burning up.
Old Oct 5, 2013 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Go to any competent automotive AC shop and have them test your system. If you have a leak, they'll find it. If it needs a charge, they can do it. R12 is expensive but still available in most places.
To A/c charging
