Brake lights help!
Old Oct 4, 2013 | 09:52 PM
jjpish68's Avatar
jjpish68
Default Brake lights help!
So my wife and I went for a ride to Ocean City tonight for dinner and to ride through town since it is Corvette Weekend to see the cars that came in.
while riding through town I was stopped luckily y a concerned citizen and not the OCPD... I was told that I had a brake light out.
We pulled over and when I step on the brake pedal my light on the drivers side goes out. Passenger side is fine. This is while my headlights are on. Turn off the headlights and step on the brake pedal and both brake lights work.
Any ideas what I have going on here?
Old Oct 5, 2013 | 09:25 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
did you try replacing the bulb?
Old Oct 5, 2013 | 10:37 PM
lvmyvt76's Avatar
lvmyvt76
he said they work correctly when the lights are turned off.
Old Oct 5, 2013 | 10:45 PM
'75's Avatar
'75
Sounds like a bad ground, I have seen several of the bulb sockets go bad. The ground connection where the black wire attaches in the socket gets rusty. If that's the case, a new socket is the best solution.
Old Oct 5, 2013 | 11:32 PM
GarthVader's Avatar
GarthVader
Check out these two threads. http://forums.corvetteforum.com/c3-t...ghts-help.html
http://forums.corvetteforum.com/c3-g...ights-out.html Not the exact same problem, but there is a nice schematic in one thread and a nice picture of the grounds in another.
Old Oct 6, 2013 | 08:23 AM
jjpish68's Avatar
jjpish68
Thanks you for the help. I will have to dig in. Thanks for pointing me in a direction.
To Brake lights help!
